585,599 active members*
3,576 visitors online*
    Feb 2015
    22
    Pulse an output?
    I'd like to have a yellow light flash on my control panel when feedrate override is active.
    I have the yellow light, power source, and a relay. I could plan a timer circuit if needed.
    Is this possible or am I dreaming?
    Now that I think of it, I don't even know if it's possible to get a solid signal out of mach when override is active.
    Any links or help is appreciated.
    Oct 2005
    1145
    Re: Pulse an output?
    you can create a brain to pulse an output.
    (;-) TP
    What is the controller type? You can modify the logic to do this.
    Feb 2015
    22
    mx4660 built in bob.
    thanks for the replies.
    I'll look more into writing a brain.
  1. Time pulse, digital output of machine controller
    By smar in forum Controller & Computer Solutions
    Last Post: 08-16-2011, 04:50 PM
  2. Pulse output on enable
    By kingofl337 in forum Mach Mill
    Last Post: 08-15-2011, 04:05 AM
  3. Unstable -- Mach 3 random output pulse
    By cjchands in forum Mach Software (ArtSoft software)
    Last Post: 11-21-2009, 07:29 AM
  4. Are their controllers that output ASCII command(instead of pulse)?
    By JasonCampbell in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-25-2007, 11:49 AM
  5. Unfit Pulse Of Pulse Coder Alarm
    By Crashmaster in forum DNC Problems and Solutions
    Last Post: 04-23-2007, 03:55 PM
