585,926 active members*
3,853 visitors online*
Results 1 to 8 of 8
    Apr 2015
    6
    Recomended encoder
    What is the recommended encoder for the current 200 drives? Full size mill electrocraft e703 motors. Current drives are FET drives rated at 80vdc and 15A. I would like the same proformace as the existing drives. Will the current litton 82bz-1000-5-3 work for a few months to finish some production runs up and swap to a differential encoder later? Or is there a good encoder for a reasonable price? Trying to same some money now but don't want to buy anything I will need to change out later to increase proformace. This is the last bit of info I need before pulling to old controller and starting a retrofit. If the existing encoders will work I will order the drives this week.
    Don
    Apr 2015
    6
    Re: Recomended encoder
    Anyone know how single ended encoders work with these drives?
    Don
    Feb 2007
    966
    Yes they will. Download the manual, and there is a diagram showing how to add a 2K res if your using single ended.
    Get the US digital encoders, they are only about $60. Don't use those cheap AMT as they are just hobby quality ( Saving $20 isn't worth it for the most important part of a servo system. )
    If your buying encoders, be sure to get differential as well.
    Larry
    Jan 2006
    204
    Larry,
    which US digital encoder would you recommend
    Thank You
    archie
    Feb 2007
    966
    E5 or E6 series . 1000-2000 line with differential outputs
    Feb 2017
    7
    Which breakout board would you recommend for these drives?
    Feb 2007
    966
    I have my own Bx7 bob on my Viper Servo motor products site,
    But also I recommend
    PMDX.COM - Products for CNC and motion control applications
    Larry K
    Feb 2017
    7
    Larry,
    When i get 3 viper 200f and the bx7 bob, what power supply would you recommend? I have sem mt30m4-59 servos 142v and 30a peak.
  1. Recomended CNC Repair near Easton, PA
    By avongil in forum USA Club House
    Last Post: 10-02-2017, 07:44 PM
  2. Power supply recomended
    By CNCmlopes in forum Stepper Motors / Drives
    Last Post: 08-18-2013, 12:20 PM
  3. Recomended research
    By jrmyron in forum CNC Tooling
    Last Post: 10-30-2012, 01:15 PM
  4. recomended inverter replacement
    By poorfarmer25 in forum DIY CNC Router Table Machines
    Last Post: 08-12-2012, 02:48 PM
  5. recomended machine control board?
    By Josh Leber in forum DIY CNC Router Table Machines
    Last Post: 03-04-2010, 03:58 AM
