585,981 active members*
4,470 visitors online*
Results 1 to 6 of 6
    Apr 2015
    93
    Cant get into the bios?
    My Tormach computer wont turn on when I switch the power on at the machine and I have to push the power button on the PC. Needless to say this is very inconvenient and I want to change the settings, but I cant get in. Holding the F2 or del key doesn't get me in. Any ideas?
    Sep 2010
    717
    Re: Cant get into the bios?
    Some computers use F10, but you should see what key it is at start.
    Current build: http://www.cnczone.com/forums/diy-cnc-router-table-machines/264838-new-machine-desing-quot-cnm13-quot.html
    Apr 2015
    93
    It used to display the keys but it doesn't anymore. Nothing seems to work. I had no issues getting into the bios before.
    Apr 2014
    185
    Quote Originally Posted by Gilmax View Post
    G'day Gil,
    I had almost exactly the same problem .... the ONLY way I could get around it was to hook up an old PS-2 keyboard and that worked.
    Form what I've been told, it turns out that on some BIOS's they load the USB drivers after the BIOS has loaded,
    which makes it very difficult to use the F2, F10 or Delete keys.
    Michael
    Jun 2006
    340
    Search the Linux CNC site.
    Or better, ask Tormach who should... must be able to answer, since their coders would have been using the keystroking frequently at some stage.
    Apr 2015
    93
    G'day Gil,
    I tried a different USB keyboard and it worked. Thanks! Its nice not to have to duck under machine stand to turn the machine on. Too bad the the Tormach keyboard was the thing giving problems.
  1. bios settings for 98 arrow 500
    By coop31 in forum Cincinnati CNC
    Last Post: 09-16-2012, 08:42 PM
  2. Centurion V BIOS / HDD info
    By hrhoward in forum Milltronics
    Last Post: 08-26-2012, 08:19 PM
  3. Can't set EPP mode in Bios
    By Realmseeker in forum Gecko Drives
    Last Post: 04-17-2011, 12:10 AM
  4. opening DOS bios
    By cyclotron in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-24-2008, 04:37 PM
  5. FUSION 640T BIOS
    By APEXWARRI in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-22-2008, 06:21 PM
