Background:
I bought my K2CNC machine, a KG4925HD with the 12 inches z-axis
upgrade, ELTE tool changer spindle, four axis servo motor
control, and it came with the Kmotion software and the driver
installed in the Dell Venue 11 Pro I was controlling with at the
time was the KFLOP motion control driver 4.xx. Everything was
operating then, save for the very shaky z-axis that now is
corrected with moving the bracket to taut the belt (as of today).
But since then, I have not been provided the last item on my
invoice, which is a dust hood for the ELTE spindle. But that is a
small issue on top of another I have as of today. See, I have a
spare Surface Pro 1 that I installed the KFLOP driver and
installed the Kmotion 4.32 software and the gantry and controls
run fine and I am able to send G-code files. The reason for the
change of PCs was that the Dell Venue 11 Pro that I have wouldn't
charge reliably or be operational when plugged in with the micro
USB cord, it more than often wouldn't charge or have power
because of the shoddy micro USB plug. But the PC issues have been
resolved.
Problem:
Now? I can no longer get any spindle commands to recognize to the
ELTE spindle. Using the jog function of the Delta power supply
that powers the 3HP ELTE tool changing spindle does have the
spindle spin. In the past when I first received the machine, the
spindle and fan would spin. Now, I can't get them to function,
all other servo motors work fine in receiving commands.
Besides finding out that my support inquiries and invoice
inquiries are no longer being accepted and to find that K2CNC is
defunct and did not provide my dust shoud for the ELTE spindle, I
wish to at least have my ELTE spindle be recognized again or to
solve why I am not able to get commands to the spindle. I am
using Kmotion's software and the KFLOP driver from Dynamotion's
site that I found an installer for my Surface Pro and got the
drivers to work by entering a state for Windows 8.1 Pro that I
can install unsigned drivers.
The Dell Venue 11 Pro, I tested and tried to see if the spindle
can be operational (have not changed any software settings or
driver settings since I got it from K2CNC) and the same result
happens. I can get the gantry to move but the spindle and
anything dealing with the ELTE spindle would not function.
I found this site after searching for some possible solutions. I
hope someone can give me some information so I can be well on my
way. I have plenty of code to execute and am ready to have my
machine working again.
TL-DR
Gantry commands, servo motors work for K2 machine. ELTE spindle
is not receiving commands. Controller problem? Can I swap boards?
What do I need to look for?
