585,974 active members*
4,338 visitors online*
Page 3 of 4 1234
Results 41 to 60 of 76
  1. #41
    Sep 2009
    While looking for metal abrasives, I found essential grinding discs. Check out photo
  2. #42
    Dec 2008
    26
    That thing looks right in my price range, along with looking like it does exactly what I am after.
    I am curious though, can I get it with the Aluminum blade or am I stuck with the steel blade and gotta buy the Aluminum one seperately?
    Later EddieO
  3. #43
    Mar 2018
    Re: Metal Cutting Chop Saw vs Abrasive Chop Saw
    Well , I can share my hubby's experience here. His first saw was a Dewalt chop saw . It functioned admirably enough but the accuracy of the cut and sparks was not so cool to him ever. He had a cutting blade expode one time and he chose to change it with a Makita LC1230 saw .
    He could never backpedal to a abrasive saw again . The cold saws are more costly yet he have observed it to be significantly more accurate, clean and secured...
  4. #44
    Aug 2020
    The abrasive saw is made of a stainless alloy that cuts stone, metal, and many other materials
  5. #45
    Feb 2021
    The content that you share with us is really informative and it gives us the knowledge of how things are. Thank you for sharing this wonderful post with us.
    Useful Links:
    Tuition Agency
    Tuition Assignments
    Homestay Singapore
    AEIS Mock Papers
  6. #46
    Mar 2021
    I’d want to use some with the content on my blog whether you don’t mind. Naturally I’ll give you a link on your web topic.
    Jake | élagueur
  7. #47
    Mar 2021
    A grating slash saw is ordinarily a table-top device implied for cutting hard materials like metal and is discernable by the kind of sharp edge or plate it employments. The cutting activity of this sort of saw is performed by a rough plate which is very much like circles found on granulating wheels however a lot more slender. The cutting haggle are mounted normally on a rotating arm appended to a fixed base. The base regularly uses an underlying tight clamp or clip to get materials. The cutting circle is ordinarily around 14 in (360 mm) in breadth and 7⁄64 in (2.8 mm) thick. Bigger saws can utilize 16 in (410 mm) width plates. Grating saws regularly use plates with precious stone and cubic boron nitride, which last more than customary edges. I'm just not sure if they use it for tree removal service.
  8. #48
    Apr 2021
    I've never tried the abrasive chop saw. A lot in here might be looking for electricians sarasota
  9. #49
    May 2021
    thanks for this blog, it help me out!
    roofing companies near me
  10. #50
    Jul 2021
    A superbly written article, if only all bloggers offered the same content as you, the internet would be a far better place. AV System Design florida
  11. #51
    Apr 2021
    Your forum post is really helpful to us. Kindly share more knowledge for the industry. credit repair tampa
  12. #52
    Aug 2021
    I think this is one of the best sources, love this website. I have found what I was looking for. A good day
  13. #53
    Aug 2021
    Sometimes it is difficult cutting inconel 600 plate. What should I do?
  14. #54
    Aug 2021
    There are many pros and cons with each method but they all seem to work for people who want are looking for the best electricians.
    https://www.bestwestelectrician.com.au
  15. #55
    Mar 2022
    happy houses is TRUSTED PROFESSIONAL HOUSE CLEANING SERVICE in different cities of USA. Established in 2009, Happy Houses Cleaning Services has become one of the most successful, dynamic and professional cleaning company in USA. We offer an unbeatable service, reliability and levels of customer care that have set an industry standard. We provide quality domestic cleaning, and office cleaning servicesto many cities.
    We provide vrbo atlantafor your Airbnb rented properties
    Travel industry experts to offer hosts guidance and best practices for cleaning and disinfecting a vacation rental property vrbo denver.
  16. #56
    Mar 2021
    Remind me again why someone would even want this.
    solar panels in australia
  17. #57
    Mar 2022
    Man I definitely adore your write-up.
    epoxy garage floor
  18. #58
    Mar 2022
    1. Concrete Paver Molds
    concrete paver moldsare used for paving walkways, patios, driveways, etc. They can be poured into forms that have been cut out of plywood or other materials. These forms are then filled with concrete and allowed to harden. Once hardened, they are removed from the forms and placed on top of each other to create a finished product.
    2. body cast Molding
    Body casting is a method of mold making where plaster of Paris is mixed with water and poured into a form. After the plaster has set, the plaster is broken away from the form and the object is left inside. This technique is often used for creating busts, heads, and limbs.
    3. Silicone Molds
    Silicone is a material that is used to make molds. Silicone is non-toxic, easy to clean, and does not react with any chemicals. Silicone is also flexible enough to allow objects to be molded easily. silicone molds for concrete
    4. Plasticine
    Plasticine is a mixture of clay and water that can be molded into any shape. It has been used for thousands of years to make figurines and toys. In recent times, plasticine has become popular among artists and crafters due to its malleability and ease of use.
    5. Play-Doh
    Play-Doh is a soft, pliable modeling material that comes in various colors. It was first introduced in the 1950s and became extremely popular in the 1970s. Today, it is still widely used by children around the world to create artworks and sculptures.
    6. Jello
    Jello is a gelatinous dessert food product that originated in the late 19th century. It is made from milk products and cornstarch and is commonly colored pink. Jello is often used as a base for other desserts and candies.
    stepping stone molds is a mold that has been used to create a series of smaller molds. These molds are then stacked together to make a larger mold. This technique allows for a much faster production time than creating each mold individually.
  19. #59
    Mar 2021
    I intended to create you a very little remark to be able to give thanks once again just for the awesome principles you have shown on this website.
    Smart Pool Heating
  20. #60
    Mar 2022
    I simply wanted to thank you very much once again. I do not know the things that I would’ve gone through in the absence of those basics revealed by you on that subject. It previously was the horrifying condition for me personally, nevertheless being able to view this skilled form you resolved it forced me to cry over gladness.
    northern beaches tree removal
Page 3 of 4 1234
  1. Why does the chop saw fence have a v-shape?
    By Plugger in forum WoodWorking Topics
    Last Post: 05-25-2011, 03:45 PM
  2. Opinions: wood chop-saw to metal chop-saw duty
    By soundmotor in forum Uncategorised MetalWorking Machines
    Last Post: 10-06-2009, 07:59 PM
  3. best basic chop saw
    By nc9933 in forum Uncategorised MetalWorking Machines
    Last Post: 11-02-2008, 09:10 PM
  4. Radial arm chop saw - bad idea?
    By roombacurious in forum Uncategorised MetalWorking Machines
    Last Post: 08-15-2008, 01:26 AM
  5. Need a saw to cut material, Band or Chop?
    By mgb1974 in forum Community Club House
    Last Post: 07-30-2008, 05:22 AM
