Originally Posted by
daniellyall
so you have done it like this
The resistor is calculated by taking the current in amps and multiplying by 1000. If your motor is rated at 2.8A per phase you will have to use a 2.8K 5% 1/4W resistor. If your motor is rated at 3.5A or above you can safely not use a current set resistor; however, your G540 will not go into current standby mode which will result in increased motor heating.
At this point you should have holding torque on the motors and a green LED lit. If you do not then the motor is wired incorrectly or is damaged.
and do you have a green light if yes : YES
do you have the ESS enabled as you selected motion devices if yes : YES
do you have your motor velocity and acceleration set if yes : I have to check that
do you have your Axis mapping set if yes : I have to check that
do you have your E stop working if yes : YES
to answer just use quote and change if yes to a no if the answer is no, if the answer is yes just leave it
