Hello, I recently purchased a board that uses an IDC 25pin interface that is then adapted to a normal parallel port size. The problem is the adaptor was not with the board and now I have a board that I can't connect. I have been trying to get a hold of the seller but with no luck. Can anybody please explain to me where I can get an adaptor. If you need a bit more info I go into more details under the benchtop mills section with the title of the thread being CNC FUSION kit with geckos, etc... It has a picture of the cable as well as the exact board I am using. Thx
