Originally Posted by
RASH1
HI JACOF
yes, only got alarm 401 v-ready off: svm and psm display ( - ) spm (- -)
When I turn on the machine, without nc control ,em plug in cx4 pin 2,3 IS closed and there is 24v in 2 and 3 !
Maybe this contact opened when I turn on the control ?
I will try to do the test (Insert a bridge between the pins) in Sun day.
the machine ready= GO229.7 IS OUTPUT FROM THE PMC TO THE CNC. I HAVE NOT FOUND THIS OUTPUT IN "Y"
Maybe the cnc need only ANY reset ? if yes, do you know how to do the reset ?
many thanks
David
VERTICAL MACHINING CENTER LEADWEEL
MODEL: MCV-610CR
SERIAL NO:LISIE0127
MFG DATE :JUL. 1995
CNC UNIT
MODEL :FANUC-0MF
MFG NO:T95420136
PSM:A06B -6077-H111A
SPM:A06B-6078-H211 #500
Y Z AMP: A06B-6079-H206A
X AMP :A06B -6079-H103A
