For the machine with 9KW ATC spindle, if the spindle speed is 18000RPM, how to change the spindle speed from 18000RPM to 24000RPM? Please check the following:
Please check the panel of inverter, set the parameter number " 0100/0101" to "400", and then set the parameter of the spindle into "24000RPM". After this, please restart the machine, it will be ok.
