586,009 active members*
4,742 visitors online*
Page 5 of 107 345671555105
Results 81 to 100 of 2130
  1. #81
    Jul 2015
    17
    Re: OmioCNC report
    Been lurking about here waiting to see if anyone is cutting anything. Not ordered my machine just yet, still leaning on the 2200 though. My main focus will be G10 and occasionally carbon fiber plate. Lots of talk about misters. Has anyone considered a tray with fluid, sort of a shallow damned pool of sorts making a constant coolant/dust containment bath?
  2. #82
    Mar 2013
    319
    Re: OmioCNC report
    Yeah that's by far the best way to cut CF in a DIY/home environment... Much better than a dust boot and hepa vac.
    I have been meaning to build one for a while after seeing it in action, but I haven't needed to cut any cf lately. I'm wondering whether to build one for the 2200L or just build a coolant tray that can be plugged to achieve both that and the ability for flood coolant.
  3. #83
    May 2015
    1422
    Re: OmioCNC report
    I built my table/enclosure with a 1" tray to catch any coolant that dropped down with the intention of running flood, but then switched to mist anyway as a plan for lubrication. Still waiting on parts to make that bit happen. Never looked at a bath.
  4. #84
    Aug 2007
    24
    What is the footprint of 2200L?
    I need to build the table and need the dimensions.
    Alex
  5. #85
    May 2015
    1422
    Re: OmioCNC report
    My enclosure is (in mm) 760w x 950d x 690h, which gives enough room to clear the motors and a bit of space for clamping fixtures overhanging the table edge but not so much room that I can clean the tray without taking the sides off.
  6. #86
    Aug 2007
    24
    Re: OmioCNC report
    Great thanks.
    Could you also tell me distance between the legs? Website shows 880 x 665 but this is including the motors. I'm interested to know what is the distance without the motors.
    Alex
  7. #87
    May 2015
    1422
    Re: OmioCNC report
    There's also the overhang of the ends of the gantry and the Y cable chain tray from the table to consider. But the base is 480mm wide by 750mm deep as a footprint for putting on a table.
    I found that the amount of mess it generates working open like that was intolerable, so made an enclosure with walls to keep it contained. You could keep on top of most of it with a vacuum cleaner and shoe if you're only working with wood. Most of it. But when working with metal and coolant the vacuum doesn't have a chance, the floor around the machine gets covered in flung coolant and evil bastard metal splinters.
  8. #88
    Aug 2007
    24
    Re: OmioCNC report
    Thank you. That's exactly whatI needed to know.
    Alex
  9. #89
    Oct 2015
    6
    Re: OmioCNC report
    Quote Originally Posted by dharmic View Post
    Quick update. Couldn't get it going yesterday but tried again today with a new install of Mach3 and hey hey, it's all running.
    A little bit of a mismatch between their tool setter documentation and the on-screen settings available in Mach3 but nothing a little mental arithmetic can't sort out.
    Only testing with a fibreboard floating floor offcut at the moment but 3000mm/min feedrate seems perfectly fine with a 0.5mm depth of cut.
    Still need to see how it goes with aluminium, and plug in the 4th axis for a bit of a play.
    But so far, so good. I'm quite impressed with how this is going.
    Quote dharmic;1733548 -Hi,I need some advice and you may be the right person to contact. I have just set up my OMIO machine identical to yours. I followed instructions provided, and I have Mach 3 software working on the laptop, power is through to the motors but when I adjust the X and Y on Mach 3 the motors don't respond and neither does the spindle. I transferred the code as directed but I am thinking I have not configured settings correctly, maybe the ports and pins? Is there something I have missed, can't get past test.
  10. #90
    Mar 2013
    319
    Re: OmioCNC report
    Have you pressed the flashing reset button on mach3?
  11. #91
    May 2015
    1422
    Re: OmioCNC report
    ^^ this.
    If it's in its emergency stop / reset state nothing's going to happen. Hit that button first, then home all axes, then start driving it around.
  12. #92
    Mar 2013
    319
    OmioCNC report
    Just as an aside, I have now replaced the spindle cable with shielded 4 core and hooked up the earth. As suggested I have gone with a star ground and I've just finished the first job after putting it all back together... Machine behaved impeccably.
    So a bit early to call it a success but early signs are indeed positive, and now my machine won't electrocute me if the spindle or wiring develops a fault and the VFD is wired as per Nowforever's instructions.
    Attachment 295120
    I do still need to fully isolate the psu and emi filter from the case, so that the earth wires are the only return path... It is however working fine at the moment as is.
  13. #93
    Oct 2015
    6
    Re: OmioCNC report
    yes done that, double checked installation procedures so many times. signal not reaching machine.
  14. #94
    Oct 2015
    6
    Re: OmioCNC report
    yes zeroed the axis but signal not reaching machine. as per my message double checked all procedures and connections. I have re-installed mach3 during the process but something is missing and can't see what, and yes control box is on and power going to motors. Have reset when indicated on mach3. damn frustrating, regards Mike
    By the way there are 2 collets that come with the machine and I have a set of 1/4" bits - does anyone know the best place in Aussie to get a 1/4" collet to suit the OMIO2200 spindle?
  15. #95
    Mar 2013
    319
    Re: OmioCNC report
    Just search for ER20 collets (assuming you have the 220v spindle) - you will find whatever size you are after.
    What windows are you running? If windows 7, have you run the memoryoverride.reg by double clicking it?
  16. #96
    Oct 2015
    6
    Re: OmioCNC report
    Yes, double clicked it when I placed it in the mach3 folder - was that the appropriate time to double click it? Then rebooted. I am thinking I need to do another uninstall and start again. With the transfer of the files are they transferred in one bundle into the root folder C:/mach3 or are the macros placed in the macro folder and the plug ins in the plug in folder?
  17. #97
    May 2015
    1422
    Re: OmioCNC report
    I expanded the zip then copied the contents of Settings into the mach3 folder. It should replace some of the files/folders in the mach3 folder, not create a new folder in there. If you've expanded the folder inside Mach3 it won't work.
    Mate, this is on page 1 (step 2) of the settings instructions pdf that came with them. I admit it took me a couple of goes where I "knew computers" and got it wrong before I stopped, engaged "stupid sheep following the instructions one by one" mode, and had great success.
    I'd remove and reinstall, and this time follow the instructions to the letter without taking shortcuts - if you do that you should be up and running in no time.
  18. #98
    May 2015
    1422
    Re: OmioCNC report
    Quote Originally Posted by zeeflyboy View Post
    Attachment 295120
    Nice work!
    Mine hasn't done a long job since the issues I had with the controller disappearing on me but I haven't seen that problem return so I haven't bothered. One day maybe
  19. #99
    May 2015
    1422
    Re: OmioCNC report
    Quote Originally Posted by Mike Fry View Post
    You could probably a 1/4" collet locally from somewhere like machineryhouse (Hare and Forbes) or similar. For the same price (about $30), you could buy a whole set ranging from 1mm to 13mm from eBay. No prizes for guessing which of these I did.
    I'm a little surprised the 6mm collet that comes with it won't open up enough to take 1/4" though - just a little bit to small?
  20. #100
    Oct 2015
    6
    Re: OmioCNC report
    Decided to stay at home at fix this CNC issue. Did a re boot. Now there is a pop up asking whether I want to use the normal printer port or the USB Mach3 etc.( that didn't come up previously) If I choose the USB I end up with an error message and Mach3 shuts down. Seems there is a conflict with drivers by the look of the error messages. If I choose normal printer port then mach3 stays on but controls don't operate axis movements on the laptop (and no movement on the machine). I have uninstalled and re installed and same thing. I uninstalled and re installed this time without the printer port driver but did the same thing. Have done the Mach3 installation exactly to the letter several times now and still no joy. I will uninstall and shut down and try again tomorrow. If no joy I will need to get the laptop looked at. By the way If it means getting another laptop will the system work with Windows 10 or will I need to retro back to Windows 7? Tomorrow's another day!
  1. Report files
    By RP Designs in forum Centroid CNC Control Products
    Last Post: 11-22-2009, 06:51 AM
  2. Machining Report
    By Tielegin in forum Esprit
    Last Post: 05-05-2009, 06:25 PM
  3. Fresh man report
    By ice in forum Commercial CNC Wood Routers
    Last Post: 09-28-2006, 11:45 AM
