Re: Feedrate moves at clearance plane?
I want to jump in here on a few topics.
#1 Upgrade to the current version... well it's true the current software version has lots of new options in all aspects of the software. If you are running V25 you are 2 version back and lots of things have be updated and changed for the better. So when it works for you to get current I recommend doing it.
#2 As far as feed moves and rapid moves for repositioning. there is an option on the links tab to handle this. You can change it from feed to rapid move. That should just be that easy.
#3 Operation stock! This is what you are looking for to keep track of material as you go. Yes you can use rest roughing which is mainly an offset that is being applied to your model. With the current version you can select operation stock for most of the pro toolpaths. The operation stock is a user loaded solid or STL file. So you can save out your cut model and load it in as your operation stock. Op stock is uses as a 3D boundary for your toolpath and can be combined with boundary options and angle ranges to better target material for rest roughing, semi finishing and finishing operations. I would recommend downloading a demo of the current version and giving it a try.
#4 Feature request is how you get changes in the software. If you don't like how the feed moves are posting when using contour ramp, then report it. Recommend how you would like to see the software work. These requests go directly to development , Software Issue Report & Feature Requests | CAD/CAM | BobCAD-CAM | BobCAD-CAM
Most of us can think of a hand full of things we would like to see changed in the software. Have you voice heard by reporting something today.
Al DePoalo
Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
