585,712 active members*
3,935 visitors online*
Results 1 to 1 of 1
    Jun 2015
    14
    HE3D Delta -600 3d printer kit
    Technical parameters:
    1.Integrated SD card with LCD monitor display.
    2.The Layer Thickness: 0.05-0.4mm
    3.Layer Resolution: 50 microns
    4.Printing Filament: PLA & ABS. Heatbed Required for ABS.
    5.Technology: Fused Deposition Molding (FDM).
    6.Construction based on parallel arm (delta).
    7.Machine dimensions: height:1120 mm width:430 mm length:430 mm , the total weight: 12 kg (including packaging)
    8.Outer frame: imported aluminum, steel (laser precision cutting)
    9.Extruder:remotely and high-speed extrusion machine
    10.The print head material: copper, aluminum, polyether ether ketone material forming
    11.Nozzle diameter: 0.4 mm (
    E3D-V6)
    12.Filament diameter: 1.75mm
    13.Nozzle number: single nozzle
    The maximum temperature of the nozzle is:280℃.
    14.Data format: STL
    15.Software: Repetier host
    16.Print size(X,Y,Z): 280×280×600mm
    17.Power input: AC110-220 - v
    18.The power supply output: DC 12 v 7 a
    19.Print plate: high borosilicate glass 310 mm in diameter
    20.Synchronous belt wheel / 16 teeth, belt GT2
    [email protected]
  1. He3D- Triple Extruder Tricolor Reprap 3D Printer
    By jiahaiqing in forum Videos
    Last Post: 06-29-2015, 06:00 AM
  2. Delta 3D Printer Kit
    By linan in forum 3D Printer / 3D Scanner Discussion
    Last Post: 04-04-2015, 09:33 AM
