585,737 active members*
4,707 visitors online*
    Jan 2004
    34
    Fanuc 6T Operators manual
    HI,
    Just recently purchased Tsugami CNC lathe with Fanuc 6T
    We have Tsugami with fanuc 10T and have some experience.
    The setting of offsets is diferent so we need Operators manual for fanuc 6T
    Anybody with scanned copy on pdf ?
    Thank you in advance
    Aug 2011
    2517
    Re: Fanuc 6T Operators manual
    generally older controls like 6T manuals are not available in pdf. it wont really help you anyway because they were not very well written, mostly translated from Japanese and confusing to newbies.
    tool position is set for EACH tool with G50 X Z
    offsets on 6T apply to WEAR only.
    in a T0101 command, the first 01 means tool 1, 2nd 01 means wear offset 1
    no geometry offsets on 6T, you must use G50 X Z
    you can find basic tool setting info here...
    http://www.cnczone.com/forums/fanuc/...ml#post1211935
    Oct 2019
    Fanuc 6t
    Nov 2007
    352
    Not alot of Difference in the controls just depends on the options that were turned on
    Parameters didnt change much to O control upgrade by early 90s and most ISO programming should still work ok
  1. Replies: 3
    Last Post: 05-22-2013, 05:59 PM
  2. YAM CK-2 operators manual
    By L98FIERO in forum Machinery Manuals / Brochures
    Last Post: 03-17-2012, 04:54 PM
  3. 15m operators manual
    By orbj32 in forum Fanuc
    Last Post: 11-28-2010, 04:24 AM
  4. HLV-H operators manual
    By BillTodd in forum Hardinge Lathes
    Last Post: 02-13-2009, 12:32 PM
