585,708 active members*
3,971 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc series 18 i-M, Daewoo diamond series DMV-500s start up error
    Jul 2015
    Hail from Jamaica,
    We have a Daewoo diamond series DMV- 500s with a Fanuc series 18i-M computer attached. We are having a startup issue, the machine is stuck at this screen:
    GRAPHIC IS READY, BOOT STARTUP
    We have four green LED and two red LED in the back not sure of the error code
    PLEASE HELP!!!!!!!!!!!!!!!!
    Feb 2015
    161
    Re: Fanuc series 18 i-M, Daewoo diamond series DMV-500s start up error
    Most likely a bad CPU. Replace it. Make an SRAM backup in boot mode first before removing the yellow case.
    If you do not already know, the CPU is located on the right when looking at the lights, as in your pictures. It plugs directly into the main board.
    Jul 2015
    Is there a way to troubleshoot the system so i can know for sure that its the CPU?
    - - - Updated - - -
    Thanks for the reply
    Feb 2015
    161
    Unfortunately, not really. Make the SRAM backup if you can and remove the other 2 larger modules on the main board and see if it boots up. If not, then it's either a CPU or Main board. Also, you could try clearing memory on startup(obviously make sure you have a good backup). Sometimes corrupt memory will make this happen.
    Oct 2016
    20
    hello friend excuse me do you have the backup of that machine because I losto the parameters, macros and all,
    this is my email [email protected] if you send me the backup please because the machine is stopped
    thank you
    regards
  1. Replies: 1
    Last Post: 11-08-2014, 06:40 PM
  2. Fanuc series o-m does not start up
    By KICKD in forum Fanuc
    Last Post: 06-25-2013, 07:34 PM
  3. Elox Fanuc Q series shutting down on start up
    By T-Lang in forum EDM Discussion General Topics
    Last Post: 11-05-2010, 03:55 PM
  4. Daewoo Diamond Series DMV-400
    By RinNguyen in forum Daewoo/Doosan
    Last Post: 12-25-2009, 11:57 PM
  5. Error L on Fanuc series 10
    By wanchai101 in forum Fanuc
    Last Post: 02-28-2006, 09:09 AM
