512,269 active members
3,891 visitors online
IndustryArena Forum > Events, Product Announcements Etc > Web Deals/coupons > He3D- Triple Extruder Tricolor Reprap 3D Printer
Results 1 to 3 of 3
    Registered
    Jun 2015
    14
    Characteristics of Triple Extruder 3D Printer:
    Allows to take print in three different material, for example PLA, ABS, PVA (realize special support material to print, PVA).
    Three different colors material.
    Use different diameter of nozzles to identify the varying thickness of printing layers. Quick print nozzle can fill the inners and fine print nozzle for outer print for smooth finishing.
    5 mm thickness aluminum alloy surface temperature, durable heat up faster.
    It is a triple extruder machine. You can use it as single as well as double extruder machine.
    Minimal sound while printing.
    Support component printing, to reduce the edge warping phenomenon the kit parcel.
    http://www.reprapmall.com/index.php?route=product/product&path=24&product_id=52
    sales@reprapmall.com
    Member
    Nov 2019
    Pinoy Lambingan Replay
    Hi, Thank you so much.
    Also Check our new work :
    We stream replays of all Pinoy Television shows, games, news, and Pinoy Tv episodes on Gma Pinoy TV and GMA News channel. Nearly all Filipinos are into getting addicted with watching various shows in tv.
    Member
    Jan 2020
    Pinoy tv tambayan
    VERY THANKFULL TO ADMIN. FOR VISIT HERE.
    If you are searching for a platform that will give you free Pinoy Tv Shows then definitely we are an ideal place to see. Watch all your favourite Pinoy TV shows online free! Pinoy Lambingan Shows that are related to Filipinos love, romance, comedy, thriller and action will be available. Our Pinoy Network will be your favorite Pinoy Tambayan channel.
    http://pinoytvlambinganhd.com/category/gma-drama/
  1. HE3D Delta -600 3d printer kit
    By jiahaiqing in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 07-04-2015, 11:31 AM
  2. He3D- Triple Extruder Tricolor Reprap 3D Printer
    By jiahaiqing in forum Videos
    Last Post: 06-29-2015, 06:00 AM
  3. Using Mach3 with Reprap extruderUsing Mach3 with Reprap extruder
    By router101 in forum General CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-03-2010, 10:46 PM
