585,758 active members*
4,310 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Looking to up size my balls.............. for my C7 ballscrews\nuts that is
Results 1 to 5 of 5
    Sep 2012
    323
    While taking my machine apart today to add an oil fitting, I noticed the ball nuts had some play in them that wasn't there before. Maybe there was some break in?
    Anyway, how much have you guys increased the size of you balls when replacing them?
    Currently they are all .1245" in the X & Y.
    Thanks,
    Andrew
    Oct 2014
    77
    Re: Looking to up size my balls.............. for my C7 ballscrews\nuts that is
    Hello,
    I have done the same to my shopmaster cnc with c7 ballscrew as well. Each axis was different on size when I did the work. One started at .1245 and I was able to go to .1265 and the other .1255. I purchased a range of balls from an eBay source and uped the size .0005 at a time till little play but the weight of the ball nut would still allow it to spin down the screw on its own while vertical before installing back into the machine. This is a very time consuming project and must be done with great care as installing to large of a ball could damage the screw in a heart beat. I installed .127 and it would not allow me to install all of the balls. But your experience may vary greatly and please do not take my size as a start point, just what I did. You must only go in small increments and may be different. Also for note, the screw may not be uniform in size the whole length therfore when you test it, you must go the whole length each time you test and may be free in one point and bind in another. Also you must count the number of balls in each circuit, as mine was not the same between screws. When I did mine I was able to add an extra ball to each circuit to make better but again if you do this you must be very careful to not cause binding and test whole length. You may not be able to do this and only try with care. Again my experience and I take no responsibility for damage. Hope that helps.
    Sent from my SM-N910V using Tapatalk
    Aug 2005
    158
    Ok, this will qualify as the "dumb question of the week".
    "I purchased a range of balls from an eBay source ..."
    Could you provide the vendor name or even the search term you used? I've tried a few different terms and have yet to come up with any meaningful results.
    Thanks.
    Oct 2014
    77
    Came from a company called ToolSupply
    here is a link to one of his auctions found while on my phone so hope the link works.
    http://m.ebay.com/itm/310348289054?ul_ref=http%3A%2F%2Frover.ebay.com%2F rover%2F0%2Fe11400.m2368.l1120%2F7%3Feuid%3D23d1f7 d973524c6fa92873c1115bdec2%26loc%3Dhttp%253A%252F% 252Fwww.ebay.com%252Fitm%252F310348289054%253F_trk sid%253Dp11400.c100295.m3564%2526_trkparms%253Daid %25253D333008%252526algo%25253DRIC.MBE%252526ao%25 253D1%252526asc%25253D20140909133853%252526meid%25 253D823f6eaa890548b18ea34215fdb1f62d%252526pid%252 53D100295%252526rk%25253D6%252526rkt%25253D8%25252 6sd%25253D310135790479%252F%253FssPageName%253DADM E%253AL%253AOC%253AUS%253A1120%26srcrot%3De11400.m 2368.l1120%26rvr_id%3D0&_trkparms=aid=333008&algo= RIC.MBE&ao=1&asc=20140909133853&meid=823f6eaa89054 8b18ea34215fdb1f62d&pid=100295&rk=6&rkt=8&sd=31013 5790479/?ssPageName=ADME:L:OC:US:1120&_trksid=p11400.c1002 95.m3564&_mwBanner=1
    Quote Originally Posted by arvidj View Post
    Thanks.
    Aug 2005
    158
    Quote Originally Posted by uberlinuxgeek View Post
  1. How common is undersized balls in Chinese ball nuts?
    By warp in forum Benchtop Machines
    Last Post: 01-21-2015, 08:56 PM
  2. Larger balls in the C7 ballscrews
    By rusmannx in forum Benchtop Machines
    Last Post: 07-17-2014, 07:08 AM
  3. Where can i buy ballscrews, icl. nuts an bearings ?
    By 19roomer68 in forum Linear and Rotary Motion
    Last Post: 06-17-2012, 02:46 AM
  4. Where to find the size of the balls of my blocks?
    By samsagaz in forum CNC Tooling
    Last Post: 02-19-2007, 01:00 AM
  5. Supplier for ballscrews,nuts for Zay conversion
    By davo727 in forum Benchtop Machines
    Last Post: 02-01-2007, 01:20 AM
