I have an air spindle and it helps if the machine spindle doesn't rotate while using it. Is there an M code or a way to lock the spindle position while machining with the aux. air spindle?
Also the A axis is very jerky with a long series of small moves, is there a parameter or setting to smooth it out?
Joe V.
