Hello guys I have two puma 400's one is inside with ac and the other is outside in a shop with out ac ,about a month ago I was having this same alarm 2161 on the machine outside I changed the lube pump and the alarm went away for a little while( about a week ) but it came back I knocked on the distribution port with a small hammer and it seemed to fix it so, back to the original problem the machine inside is now doing the same thing could it be that maybe the pump is getting trash inside the tank and then sending it thru the lines and clogging up the distribution ports on both machines??? or is there a different issue I don't know about
