585,930 active members*
4,875 visitors online*
Thread: Door lock
    Apr 2013
    70
    Door lock
    Just had a board go bad in my 2012 VF-2 which required completely reinstall of the operating system. Unfortunately the new software now requires at least one door open to manually change tools. Before I had one of the door locks removed and just required a quick removal of the key to power up. Is there a workaround to keep from pulling the key every time I manually change the tool. No wonder the good book says woe unto Lawyers.
    Dec 2004
    126
    Re: Door lock
    a momentary button to trick the control is what I have had to do on a mori ,,,, run down the wires to the lock and see what its looking for
    Dec 2011
    295
    Re: Door lock
    Open the other door, the one withthe lock. You did say the new software needs one door to be open to change tools. Whats confusing me, is how you could manually change tools without at least one door open
    Feb 2010
    1184
    Re: Door lock
    Quote Originally Posted by LeWhite View Post
    Someone with the door safety switch bypassed could do it with the door closed.
    IDIOD, the short answer to your question is no. It is a safety feature built into the software.
    Apr 2013
    70
    Re: Door lock
    I understand the Liability behind the safety switch. Common sense would also tell me the mill would be a lot safer with the electric unhooked. It just isn't as productive. Just my uneducated .02...
  1. Door lock
    By drogers in forum Cincinnati CNC
    Last Post: 03-30-2014, 11:27 PM
  2. mori seiki door lock
    By guardianind in forum USA Club House
    Last Post: 02-28-2014, 02:46 AM
  3. Machine door safety lock
    By jkowal in forum Uncategorised MetalWorking Machines
    Last Post: 05-02-2012, 03:35 PM
  4. Mazatrol Dual Turn Fusion 640T (Door lock question)
    By Sammeh in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-22-2010, 04:06 PM
  5. Preferred stepper motor type for a door lock
    By grandruby in forum Stepper Motors / Drives
    Last Post: 08-20-2010, 01:25 AM
