585,589 active members*
3,520 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > STL, RLF or V3M to Gcode?
Results 1 to 6 of 6
    Feb 2013
    27
    All I want to do, to start with, is to carve commercially available designs (i.e. Vector Art 3D, Inc. - Dimensional Clip Art for CNC Routing and Engraving) into wood.
    The common file types seem to be STL, RLF or V3M.
    All I have found so far to convert the files to gcode is MeshCam, which is expensive, and has all kinds of stuff that I will probably never use.
    Anybody have advice on other options?
    Thanx, Alan
    Re: STL, RLF or V3M to Gcode?
    Vector Art 3D offers a free program to do this, called 3D machinist.
    Vector Art 3D, Inc. - Dimensional Clip Art for CNC Routing and Engraving - Download Free 3D Models
    It only works with designs purchased from them, though.
    Feb 2009
    2143
    STLs can be toolpathed in a lot of CAM packages. I know BobCAD and DeskProto both can use them.
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
    Feb 2013
    27
    BobCad is only slightly less money and seem to have a bad reputation.
    Am going to try DeskProto (trial).
    Feb 2013
    27
    So far, like DeskProto, but there is one really strange thing.
    When you generate a .nc, it saves it as .iso, then you have to rename it before Mach4 will recognize it.
    OK- the problem was that even though it said "nc" what it meant was gcode for whatever machine you specified in setup. When I changed setup to Mach3 it started saving as .tap.
    You might also want to look at CamBam.
  1. CAD to Gcode
    By chinthakahk in forum CamSoft Products
    Last Post: 12-16-2007, 01:09 PM
  2. Replies: 0
    Last Post: 03-10-2005, 07:46 PM
  3. Help with gcode
    By chas in forum G-Code Programing
    Last Post: 02-19-2005, 02:05 PM
  4. GCode
    By rogerbureau in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-07-2005, 02:36 PM
  5. gcode to gcode converter
    By july_favre in forum Uncategorised CAM Discussion
    Last Post: 05-25-2004, 12:51 AM
