Hi !
i would very thankful if some one could tell me how to convert a solidworks file to either DXF or g-code
Hi !
MAke a drawing of your model (in 2D) then save it as a DXF (go to pull down window in the "save as" tool bar). Be sure that your drawing scale is 1:1 or you will have an a shrinken, or enlarged part.
If you want g-code you will have to buy CAM software or write your code by hand.
Ditto igor on the DXF thing.
www.integratedmechanical.ca
thanks Igor!
but the solidworks file i have now is a 3D model can i convert it to 2D or g-code?
jmjm
Igor already splained that.
Please do the tuturials for creating drawings - seems like you need to
