585,996 active members*
4,877 visitors online*
Results 1 to 8 of 8
    Jun 2008
    262
    Need more CONTROL Flashforge with Replicator Not enough!
    I'm a nubie to this. I've been running my printer from the SD card for a few months. I finally got the Replicator to connect to the printer. I was expecting to be able to control the bed temperature and print speed with my mouse and computer but I can't find it.
    Do I need another program to do this? I actually can't find any way (printer or computer) to control the bed temp......and that's important I think !
    Nelson
    i build the braces that keep american teeth straight......tick tick tick
    Sep 2013
    147
    Re: Need more CONTROL Flashforge with Replicator Not enough!
    The easiest way to control the bed temp using rep is by modifying the Gcode before sending it to your printer. Also it's best to print from a sd card as it is more reliable.
    Sep 2013
    147
    Makerbot desktop is another option it a lot of people recommend it for dualtrusion.
    Jun 2008
    262
    Hey thanks!
    I don't know if you are familiar with Replicator, but when you go to make the Gcode you get a box inquiring about temps, raft, supports, which of the dual extruders to use, but nothing about bed temp. Sure I could change the code but I'm in streamline mode now....trying to make this quicker. I'll scope out Makerbot to see what it's got.
    Sep 2013
    147
    I only use replicator for updating the firmware now. You can change the code but I don't remember how off hand. If you use the quick setting box I think the changes need to be done in the startup script. I can look at it some more in the next day or 2 if you don't get it figured out before.
    Jun 2008
    262
    Startup script??? Thanks, I'll look for it. They shoulda put it in that Gcode parameter dialog box
    Sep 2013
    147
    I finally had time to check on this. What machine are you running? What version of replicator G?
    Sep 2013
    147
    For example using repg sailfish and a creator x. Goto c:\programfiles (x86)\replicatorg salifish\replicatorg-0040-sailfish\machines\replicator\dual_head_start.gcode . Search for m109 then set the s value after that to your desired hotbed temp. Should look something like this (m109 s110) t0 (set hbp temperature)- that would give you a hotbed temp of 110°
  1. Makerbot Replicator 2 for sale :)
    By mike^3 in forum 3D Printer / 3D Scanner Discussion
    Last Post: 11-19-2013, 07:56 PM
  2. Replicator in Dalls?
    By drermer in forum 3D Printer / 3D Scanner Discussion
    Last Post: 05-23-2013, 06:05 PM
  3. Replies: 28
    Last Post: 03-01-2013, 04:06 PM
  4. as anybody ever heard of the cybaman replicator
    By ataxy in forum Benchtop Machines
    Last Post: 10-19-2011, 02:55 AM
  5. RS-232 Prot Replicator
    By dafowfidy in forum Haas Mills
    Last Post: 01-02-2009, 01:44 AM
