585,727 active members*
4,040 visitors online*
IndustryArena Forum > MetalWorking Machines > Drilling- and Milling Machines > Which one? Minitech GX 5 Axis or Tormach PCNC 770
Results 1 to 8 of 8
    Jul 2015
    6
    Hello everyone,
    Now please excuse me I'm new and don't know much about CNC milling at all. I'm looking at getting myself a cnc milling machine to make small sub .5cc two stroke diesel engines and w ould like any suggestion to machine I should look at. I've requested quotes from Minitech and Tormac, but if anyone can suggest a cheaper hobby machine it will be welcome. I can post picture of parts if you would like more info. I don't want to spend much more than $15k. The photos are only for illustration and are not the engine I'm looking at building, but similar.
    Jan 2007
    1795
    Re: Which one? Minitech GX 5 Axis or Tormach PCNC 770
    for those parts, you going to need both, lathe and mill too...
    NL-150 Shop Series CNC Lathe
    NM-145 Bench Series 2
    you also can go on the route buying the grizzly mill and the conversion kit.. I believe somewhere 2500-3000 you have a decent small mill..
    Jul 2015
    6
    Thanks mate, this may sound very dum as I said I know nothing about these things, but why would one go for a mill and lathe not a 4 axis cnc mill?
    Which grizzly model were you referring too?
    I suppose the NL-150 and NM-145 can be used for hardened steel or cast iron(pistons and sleeves)?
    Jan 2007
    1795
    well
    some parts, even can be made on 4th axis, faster with lathe... and simpler..
    while I did not mention, even you have lathe still you need 4h axis..
    by the way, you can try to buy only a mill and experimenting..
    this is the grizzly mill many folks converted to cnc
    g0704.com
    Jun 2015
    17
    In the same boat and pretty much the same type of parts/features.
    I've weighed various options from EBAY CNC machines from China, to DIY, and now have come full circle to the complete CNC via Tormach and others.
    My rationale...was interested in the DIY part so I can build my system with my own 2 hands...blah blah blah. But after some serious thinking, I wasn't really interested in building the machine but the parts that it needed to make so I can build my "real stuff".
    There is a company who started his posts on here and a user just received his 1st mill. Skyfire SVM-0 model ($3700). You can see the build on the forum. Be careful though, make sure you read through the full thread, growing pains of an international mfr? I would jump all over this mill, but reluctant to order and unknowingly wait.
    I'm leaning towards the Tormach at 6895 or even buying a used system. You can easily begin to float towards the used HAAS markets for around 10-12k. I know, my budget was really only 2500-3500. But started doing pros-cons and my time was getting expensive.
    Just saw Minitech, what was their base price?
    Just my 2 cents.
    Jul 2015
    6
    Quote Originally Posted by why9faster View Post
    Just my 2 cents.
    Price Quotation for the CNC Mini-MillI/3 PRO
    Date: April 2014
    CNC Mini-Mill/3 Pro shown with 4th Axis Rotary Table (option)
    Quotation:
    STANDARD FEATURES
    Production components that require very little maintenance, including ball screws, brushless spindle motor, low run-out spindle options, axis drive motor splash guards, precision linear rail ways to eliminate stick slip and provide precise – smooth contours which mean less finishing time for you. Standard axis drive motors are micro-stepper driven.
    MACHINE SPECIFICATIONS:
    Specifications
    Inch
    Mm
    Overall Size
    22.0" x 22.0" x 23.0"
    560 x 560 x550mm
    Table Size
    6.0" x 14.0"
    133 x 355mm
    X,Y,Z Axis Travel
    12.0" x 9.0" x 9.0"
    300 x 200 x 200mm
    Feed Rates
    .1 to 150 IPM linear
    .1 to 50 IPM 3-axis simultaneous
    Stepper Motors
    400 steps per revolution in full step mode, rated at 250 oz. in.
    Drivers
    Standard Step Modes: 1:16 Micro stepping mode
    Resolution
    Standard: 0.00003", 0.00078125mm
    Table Mechanism
    Dual linear ball bearing slides on each axis, sealed. THK(tm) linear slides - RSR15 series, Caged-ball technology
    Drive Mechanism
    THKtm Ball Screw actuator - preloaded and sealed, 5mm pitch, this model achieves no torque fluctuation and no backlash, Positioning repeatability of the ball screw is 0.0004mm, 16mm diameter, 5mm pitch
    Hold Down Type
    Table top 1/4"-20 mounting holes, 1" centers
    Spindle System
    See attached pricelist for available spindles
    Spindle Rotation
    Spindle manually rotates 90 degrees in both directions
    Tool Chuck
    Collets, 1/8” included other sizes available
    Machine Weight
    100 lbs.
    45 Kg
    Electronics
    PC Interface
    Parallel Port Interface LPT1
    Drive Type
    Bi-polar chopper, 10 amp with micro-stepping settings, 1/10 Micro
    Number of drives
    3, with 3-axis simultaneous control (optional 4th axis)
    Power Input
    110 VAC (220 VAC), converts to 40 VDC
    Memory Type
    non volatile memory, needs use of computer to run part programs and control machine
    Interface
    TTL signal from serial port (RS-232). All cables supplied
    Input Logic
    Up to 8 input TTL signals
    Output Logic
    Up to 8 output for limit, home, or safety switches.
    Software Features:
    Minitech CNC motion control software is a Windows ® PC Based control (PC not included) G & M Code Programming. Includes 3 Axis Expandable to 6 axis.
    For more Detailed Information on the CNC Control software please see the website: www.minitech.com/support
    Terms and Ordering Procedure:
    A Signed Purchase order is required along with 50% deposit due at time of ordering.
    Company check or wire transfer are accepted. Balance due prior to shipping.
    Estimated delivery as of date of this proposal is 4 to 6 weeks from time of ordering and receipt of deposit.
    Price and specifications valid for 30 days
    All sales are subject to Minitech’s Terms and Conditions found at www.minitech.com
    The Mini-Mill/3 Pro with upgraded spindle and tool tip/home sensors is ideally suited for the machining of small designs using production of parts in three axes.
    The Mini-Mill/3 Pro is made by Minitech Machinery Corp. in Norcross, GA, U.S.A.
    Installation and Training Available and Priced on Request
    The Installation and Training involves the on-site setup of the equipment. This will include setup of the machine and interfacing to the computer. All equipment will be tested for proper alignment and calibration. The training will include being able to work with your employees so that they feel comfortable and knowledgeable in operating the equipment and software.
    Warranty:
    One Year limited warranty on the machine, limit switch/home sensors and spindle system.
    BASE Machine Mini-mill 3 pro ​$12,000.00
    NSK Spindle 0-25000 RPM​​$ 2,600.00
    CNTL4 multi axis controller with computer,
    Software, Limit switches and tool probe kit​$ 1,450.00
    RT4 X, 4th axis rotary table and tail stock​$ 1,850.00
    Price $17,900.00
    Upgrade to 5 axis……………………………..$ 5400.00
    Ordering Procedure
    Your Purchase order should be made out to and sent to:
    Minitech Machinery Corporation
    6050 Peachtree Parkway, Suite 240-205
    Norcross, GA 30092
    Fax a Copy of the PO to 775-942-1084
    Be sure to include your deposit.
    We do accept Credit Cards and ask that you call us with the card number.
    Once the deposit is received your machine will be entered into our production schedule. All machines are built to order.
    Minitech CNC Online
    www.MinitechCNC.com
    Phone 702.400.3460
    Fax 775.942.1084
    [email protected]
    David Cummings
    International Sales Manager
    Minitech Pricing
    March 2014
    Machine base with motors
    Part Number
    Price
    CNC Mini-Mill/3
    DMS-03
    12,000.00
    Spindle Options - Add On Prices
    2800 RPM, 1/4HP
    BD-2800
    550.00
    10,000 RPM, 1/4HP
    BD-10000
    650.00
    NSK E2530, precision 25K RPM
    NSK-2530
    2,600.00
    NSK E3000, precision 60K RPM
    NSK-3000
    4,300.00
    IMT 1.5 HP, 60K RPM, Precision
    IMT-60K
    5,500.00
    Controls - Add-On Prices
    Control1 - 3 Axis with software
    Cntl-01
    450.00
    Control2 - 3 Axis, CNC Control Software, Computer
    Cntl-02
    750.00
    Control3 - 3 Axis, CNC Control Software, Tool Probe & Home Switches
    Cntl-04
    1,150.00
    Control4 - 3 Axis, CNC Control Software, Computer, Tool Probe & Home Switches
    Cntl-04
    1,450.00
    Axis Add-Ons
    4th Axis with tailstock, drive added to controller, upgrade in software
    RT-4X
    1,850.00
    4thh and 5th Axis Trunnion table, drive added to controller, upgrade in software
    TT-5X
    5,400.00
    Enclosure - For Mill/2, Mill/3 and Mill/GX
    EC-02
    2,950.00
    ATC - 5 tool for NSK E3000 Spindle
    ATC-NSK-3000
    6,500.00
    ATC - 5 tool for IMT Spindle
    ATC-IMT
    7,500.00
    Pneumatic Vise with vacuum pump
    PVAC-01
    1,750.00
    MINITECH CNC www.MinitechCNC.com United States of America
    Jun 2015
    17
    Seriously 12k for a base CNC and further upgrades pushing the system to almost 20k?
    For these prices, I could certainly look for a used HAAS or even purchase a base Tormach for 7k. Wow, and this is for a small bench top mill?
    I'm not running a machine shop for production but for my own needs. Making parts for others is not my priority in the sense of a job-shop. Speed is important but only because I'm impatient. I would prefer some level of precision and repeatability but I don't want to purchase Mori-seki type mills either. WTF?
    Sounds like I might have to do a Seig conversion to get these prices or hopefully the Chinese guy Skyfire can get his act together so I can buy from him.
    Sigh...
    Jan 2007
    1795
    I have doubt about these machines could deal with tolerance these miniatures requiring..
    0.01 mm already makes difference , in fact compression decreasing too much...
    hardly can visualize example you making the cylinder head, or pistonrod..
    cylinder inside not only need to be within tolerance also the hole need to be ""honed"""
    while parts are not ""complex"" companies that producing commercially they have serious setup for.. measuring a 5-7 mm hole 20-30 mm length ... is not simple..
    good luck with your project...
  1. 4th axis milling on my Tormach PCNC 770
    By 05kevin in forum Videos
    Last Post: 04-11-2014, 02:50 PM
  2. Replies: 10
    Last Post: 05-15-2012, 04:52 AM
  3. 4th axis milling on my Tormach PCNC 770 part 2
    By 05kevin in forum Tormach Personal CNC Mill
    Last Post: 04-12-2012, 07:33 PM
  4. 4th axis milling on my Tormach PCNC 770
    Last Post: 04-08-2012, 06:26 AM
  5. Tormach PCNC 1100 Fourth Axis Table as a C Axis
    By CNC-Dude in forum Tormach Personal CNC Mill
    Last Post: 01-08-2012, 12:49 PM
