585,991 active members*
6,480 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > D&M 4 machining center Documentation?
Page 4 of 4 234
Results 61 to 68 of 68
  1. #61
    Apr 2009
    11
    Quote Originally Posted by jeffrodriguez View Post
    Hey everyone. I'm looking for some help with my D&M 4.
    I'm a new teacher and the classroom I took over has one of these machines in it. (I've attached a few pictures). Right now, when I turn the machine on, the stall light blinks and I can't do anything. None of the controls work.
    After opening the back, and reading this thread, you can see my machine doesn't have the onboard floppy drive. With some fiddling around withe front panel connections, I've managed to get the spindle to spin up and change speed.
    I'm looking for any help and information about how to get this machine operational again. I have the original software on 5.25" floppy disks, but I don't have the original computer (or a floppy drive) to connect to it.
    I do have a newer desktop that I can use, I assume, to run EMC2 and control it.
    I would greatly appreciate any help with this machine. I would like to have the students create small plastic and wood projects with the machine.
    Hi Jeff, hopefully this isn't too little too late.. but it's been a while since I was in this forum.
    As far as the on-board computer on that unit.. if you're going to have EMC drive movement, ditch it. I have a D&M5s (basically the same unit) which I converted to EMC some time ago. I'm using it for exactly the same small plastc and wood projects (even some metals) you are describing.
    My conversion (which is actually now in Phase 2) started with gutting the internal computer and replacing it with the breakout board from Campbell Designs. It's a good board, and Bob Campbell provides great support for it.
    Campbell Designs - CNC with Bob Campbell
    This board gives you the ability to hook up the parallel port from the computer running EMC, and then connect up all of the driver boards inside the D&M unit to step and direction pins from the breakout board.
    The 5s has a very nice electronic speed controller that the 4s does not (I believe) so you will definitely want to look into something to control the motor speed. I think Dale found a link to the one the 5s is using somewhere back in this forum.
    This, and some tweaking in EMC gives very good results and the machine works well.
    On to Phase 2:
    Phase 2 was a conversion from the old, round, Vektrix (sp?) stepper motors to nice, new, powerful Keling motors and trading out the Campbel BOB for a Gecko 540 controller. Essentially simplified all of the electronics very nicely.
    I also added the backlash adjuster for the Z axis at this time. It's a little tweaky.. but it works. The backlash on the Z axis right now sits around .004".
    Phase 3:
    I am currently replacing the D&M stepper motor mounts/couplings which have HORRIBLE end play in general. They essentially just replace the handwheel with a motor mount and a little splined rubber coupling for the stepper. I was experiencing on the order of .01 backlash with this configuration.
    I have since replaced the X axis mount with the CMMS from A2Z. It's a nice setup and A2Z has given great support.. I had an ordering mixup with them but they were VERY quick to step up and get it fixed. This conversion took the backlash down below .003" and will get better when I make a couple tweaks in the backash adjustment on the axis.
    The Y axis is currently being converted (the machine is now in pieces on my bench) with the Sherline CNC motor mount. When it's done it will probably be down around where the X axis is for backlash.
    Phases 4 through infinity:
    At some point, because of the bad end play in the D&M Motor mounts/couplings I'll be replacing the Motor Mount for the Z axis with either the Sherline or A2Z units, possibly adding a 4th axis and adding a Arduino controlled "front panel to EMC" interface to the enclosure itself.
    As for doing stuff with your class.. it's a great machine for that. I'd even HIGHLY recommend getting them in on the conversion as well if practical.
    Hope this helps.... Please feel free to PM (it may get a faster response) me if you need more information and I'll provide what I can.
    Michael
  2. #62
    Apr 2009
    11
    Sorry.. I got my models mixed up.. The Mill that I have is the D&M4s.. not the 5s (the 5s is a Lathe I think)...
    Just figured I should clarify..
    Michael
  3. #63
    Nov 2010
    I'm very new to the D&M 4's maching center. I picked up the machine about a year ago and its been non stop trouble getting it operational. Is there any write ups for the retrofit? Any help I'd gladly appreciate it.
    Thanks, Alex
  4. #64
    Mar 2004
    191
    I purchased one of these about 6 years ago. I retrofitted it with a hobbycnc board and new steppers and run Mach 3. I am very happy with the results.
    Randy
  5. #65
    Jun 2012
    34
    Add me to the D&M4 list. I just picked one up yesterday for $350. I've already ordered a new belt, a vise, and a bunch of tooling. I gutted the old boards and will be ordering a gecko g540, power sourse, and new motors today.
  6. #66
    May 2006
    12
    Hi Guys, I know this is an old thread but I am looking for some help.
    I am converting a D&M 4 with a C10 breakout board and need help with the 4 wires from the drivers to the bob.
    I tried red to +5, BLACK to - , orange and brown to control pins on bob.
    I have C10's on 3 other home built machines with no problems.
    Mine looks like the D&M4 on page 1.
    Thanks for any help...Glen
    PS. Will post pics. later promise.
  7. #67
    Jan 2011
    129
    Quote Originally Posted by captianpattson View Post
    please add me to the list, i just got one too.
    thanks, chuck
  8. #68
    Jun 2003
    242
    Super old thread but I have a D&M6, the old 386 lights up but I've never been able to get it to do anything so a copy of the manual would be great. I'd like to see if it will still run with the old software but plan on replacing the drives and controller anyway. It came out of a school about 8 or 10 years ago looks like it never did more than a few hours cutting signs of kids names in plexiglass.
    This machine isn't a Sherline or at least not like any on their site, it has a full height column unlike the Sherlines, has an R8 taper that is driven by a timing belt.
Page 4 of 4 234
