Hi
I'm trying to size up my expectations and also what to buy for my AMAT25LV CNC project, and I'm prepearing an excel sheet with calculations for all kinds of stuff related to loads, friction, speeds, times, forces, acceleration and inertia.
Though I do not fully understand how to use all the numbers, I have gotten some numbers out. I understand that if these numbers are correct, they are still the best of what can be done, and it's wise not to expect the machine to perform this way.
Basically I'm asking if anyone has experience with this stuff, and if this looks correct.
X-axis for example:
I'm calculating with a 0,353Nm brushed DC servo motor. Coupled via a 2:5 ratio pulley and belt arrangement. A 700mm long 1605 ballscrew, 200kg of total weight on the table 0,2 friction coefficient from dovetails. 0,00003kg/m^2 inertia on the motor. 0,0000354kg/m^2 inertia for the ballscrew (I'm excluding pulleys and belt at the moment). For the motor I have expected 3750rpm, from the datasheet it has a no load speed of 4700rpm, and the general knowledge seems to be that the motor can handle about 80% of that speed while still maintaining 80% of the torque.
This setup gives me 125mm/s for full speed.
About 500N in linear force from the servo motor via the pulley.
Which in turn gives me an acceleration time with a 200kg load of 0,05seconds, and a distance of 3,125mm. This is without the inertia of the motor and ballscrew, but as far as I can tell from my numbers just the drive assembly inertia would give me about 2100rev/s^2 of angular acceleration. Full ballscrew revolutions of 1500rpm within 0,012seconds!
All these calculations are done with the constant torque of the motor, and this all seems too good to be true, is it?
-Marius
