585,722 active members*
4,607 visitors online*
    Mar 2007
    49
    Electronic gearing
    Does the open source firmware have the capability/possibility to implement an electronic gearing function? I want to create an electronic leadscrew for my lathe and it would be nice if I could get the drive to do the heavy lifting, and just have to create some kind of simple interface to program it.
    Brian
    Mar 2007
    49
    Re: Electronic gearing
    I have looked through some of the code, and it appears this would be possible. Is the latest open source code available on GitHub? GitHub has v1.006, and the Granite Devices talks about v2.0. Is 2.0 the motor control firmware, or the front end firmware?
    Brian
    24220
    The CNC servo controllers have to be under the control of a single controller not individual drives controlled separately as in Mach.
    IOW the PID loop/encoders have to return to the single controller in order to gear one encoder off another in master/slave mode.
    I believe Dynomotion/Kflop will do it.
    Al..
    Albert E.
    Mar 2007
    49
    Al,
    I'm not sure your familer with my intended usage. This would be for a manual lathe, but instead of a mechanical gearbox linking the lead screw to the spindle, it would be done electronically via a spindle encoder and a servo driving the leadscrew. There is no need for a central motion controller, as there is only one servo.
    The Argon drive Guidebook says it supports quadrature input as a means of set point input. This is half the battle, and the only thing left to create is a scaler between the quadrature input and the drive command.
    Some servo drives already incorporate this functionality already, so, it's nothing new. What is so exciting about the Argon is the possibility of adding lathe leadscrew specific functionality.
    Brian
    24220
    I see, this appears to be a different application that the one I am accustomed to using Galil cards etc.
    Al.
    Albert E.
  1. Master and slave electronic gearing
    By rainman in forum Stepper Motors / Drives
    Last Post: 12-22-2010, 02:53 PM
  2. What gearing should I use?
    By 1armsbandit in forum DIY CNC Router Table Machines
    Last Post: 01-17-2010, 11:50 PM
  3. Electronic speed control vs gearing/belting
    By serriadh in forum Mini Lathe
    Last Post: 12-23-2009, 11:41 PM
  4. Gearing ????
    By VSNT in forum DIY CNC Router Table Machines
    Last Post: 08-31-2007, 06:51 PM
  5. Need help on Gearing
    By CAM_MAN in forum DIY CNC Router Table Machines
    Last Post: 04-05-2006, 06:23 PM
