585,589 active members*
3,745 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > Just got my 60w ebay laser (glass ring end of laser unglued)
Results 1 to 9 of 9
    Mar 2013
    24
    60w ebay laser tube glass ring was unglued when it arrived, tube was installed already. Does anyone know what glue to use to glue it back. I'm new to all this, my first laser. Also the spot weld next to the lid upon opening 2 times broke where the air shock is mounted. I will beef this area up from underneath.
    Attachment 287738
    Attachment 287740
    Nov 2010
    787
    Re: Just got my 60w ebay laser (glass ring end of laser unglued)
    Before you start repairing first check if the laser still works at all.
    Move the ring slightly away from laser path and make short test.
    2-3 seconds test laser will survive without problem.
    CNC lasers, constructions, service
    Mar 2013
    24
    Ok I just tested the laser and it works, so now what would be the best way to go about it to glue it back?
    Mar 2015
    79
    Quote Originally Posted by sixstringlz View Post
    Do a search on that.
    I believe I read epoxy and a fiberglass mat but don't quote me. I know it's been done successfully.
    Gozzie
    Mar 2013
    24
    Ok, I'll keep looking. If anyone has done this please let me know how you did it, thanks
    Nov 2010
    787
    I would start looking for glue :-)
    Mar 2013
    24
    Quote Originally Posted by cinematic2 View Post
    I guess I'll give some 30min epoxy a try.
    Mar 2013
    24
    Looks like 30min epoxy did the trick!
    what epoxy did you use? I tried epoxy for glass bit it still detaches it.
    I dont know if jb welder is going to be a good idea.
  1. Replies: 0
    Last Post: 06-11-2014, 10:10 AM
  2. Laser lid glass?
    By MechanoMan in forum Laser Hardware
    Last Post: 05-31-2014, 10:32 AM
  3. Laser Engraving on Glass
    By Roswell75 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-13-2012, 08:10 PM
