585,763 active members*
4,069 visitors online*
IndustryArena Forum > MetalWorking Machines > Mikinimech > Where can I find a new drawbar?
Results 1 to 8 of 8
    Aug 2010
    599
    The threads have finally stripped on mine and now I can't hold some of my tools.
    warmachinellc.com
    Jul 2006
    367
    Re: Where can I find a new drawbar?
    I make my own. I'll post some info later tonight
    pete
    Aug 2010
    599
    Quote Originally Posted by slowtwitch View Post
    That's what I figured. Do you make from scratch and from what material?
    warmachinellc.com
    Jul 2006
    367
    I buy grade 8 bolts (7/16x20) from Mcmaster (part # 91257A487). Look at the pdf, (don't mind the bad pdf drawing, I'm a rank beginner at this cad stuff), but it will give you an idea of how I made mine. The hex is 5/8" 4140 , also from Mcmaster.
    The intermediate part is made from some round stock I have laying around. I turned it to act as a guide for the hole at the top of the spindle nd to help in releasing the collets.
    In my situation, using my power drawbar thing, I hardened the Hex portion and use two roll pins to hold it in place (the pdf does not show the holes on the end of the bolt) . The harding really helps with using a power drawbar.
    All the sizes are approximate (I'm at work and I just winged this from the top of my head
    pete
    Aug 2010
    599
    Thanks Pete,
    I ended up having a friend make pretty much an identical copy on his lathe. Once I got it I realized it needed a minor diameter tweak and rather than send it back and since I don't have a lathe I did it on the machine using it as a vertical lathe.
    warmachinellc.com
    Aug 2010
    599
    I machined the hex today and opted for a 3/4" drive to match my vise, I then heat treated it with a MAPP gas torch and used motor oil. I'm now tempering it at 350F for an hour. This one is made from 1215 steel but next time I'll use 4140.
    Attachment 288366
    Attachment 288368
    Attachment 288370
    Attachment 288372
    Attachment 288376
    Attachment 288378
    Attachment 288380
    Attachment 288382
    warmachinellc.com
    Jul 2006
    367
    Nice job, Jim !!!!
    pete
    Apr 2005
    1268
    That turned out nice!
    Bill
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
  1. VF2 Drawbar
    By rrbmachining in forum Haas Mills
    Last Post: 12-15-2023, 08:24 PM
  2. in need of a drawbar
    By LEARN in forum Charter Oak Automation Support Forum
    Last Post: 05-24-2015, 02:23 PM
  3. 30Taper YCM30 Drawbar or power drawbar options.
    By countryguy in forum Knee Vertical Mills
    Last Post: 12-28-2014, 06:15 AM
  4. drawbar
    By advt001 in forum Cincinnati CNC
    Last Post: 11-24-2008, 12:49 AM
  5. Where to buy a drawbar?
    By MrWild in forum Bridgeport / Hardinge Mills
    Last Post: 08-01-2006, 12:44 AM
