585,982 active members*
4,606 visitors online*
IndustryArena Forum > MetalWorking Machines > Mikinimech > New machine door upgrade
    Aug 2010
    599
    Hi everybody,
    One of the things I always hated was the hinged door on the front of the machine. I was just a matter of time until is broke off. I also didn't like having to swing wide to open it leaking coolant all over the floor, the vise lead screw would push it open when moving + in Y, it leaked, and was not a great fit. Well the door fell off a few months ago so I had to fix it. Here is what I did. Much preferring a sliding type door I cut a piece of 3/8" channel aluminum extrusion and milled some of it away so that it sort of hooks over the sheet metal enclosure of the machine's doorway. This was to become the rail on which the door would slide. Converting this door to a sliding door was tricky because the Lexan piece as designed was to swing into the machine slightly to make its seal and this meant a compound motion must be incorporated into the door if it is to slide, over and in to close, out and over to open. I siliconed some 3/8" shower drip edge type material around the perimeter of the existing Lexan. I built an aluminum rail at the top of the door to allow the top side to ride on it when the door was pivoted out. Next I put an adhesive strip of D shaped flexible tubing across the extrusion to ride in the channel of the drip edge although this eventually came off. I then milled a shallow slot in the extrusion for the D shaped tubing and glued it in place. Later I siliconed the corners of the machine opening to make sure coolant would not leak out when hit with spray. I haven't really tried it extensively yet but so far what I have done it has worked great. The added benefit is now the the door is about an inch or so further out so the vise both doesn't hit it when at maximum Y travel. To open it you tilt the top of the door out about an inch and slide to the left where the top of the door will ride on the aluminum bar. To close it you slide it all the way to the right and when it clear the aluminum bar it simply falls into the machine and the stripping buts up against the gaskets making a nice seal again.
    closed
    Attachment 287880
    open
    Attachment 287882
    open
    Attachment 287884
    closed
    Attachment 287886
    extrusion threshold
    Attachment 287888
    warmachinellc.com
    Jul 2006
    367
    Re: New machine door upgrade
    Great job !!!! I've been looking at alternatives for my door (hate the swing out thing) Thanks !!!!!
    pete
    Feb 2009
    2143
    Looks nice!
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
    Aug 2010
    599
    Thanks Mike!
    Here is a video of the door:
    warmachinellc.com
    Aug 2010
    599
    Here is something I had to modify once I started using it with lots of flood. I was still getting leaking from the corner and when I would slide the door open the channel in the extrusion would be full of coolant and over flowing. So I counter-bored the middle hole a little to fit some tubing, drilled a hole in the machine enclosure and directed the tubing into that (I drilled the first hole too high like an idiot). Then I drilled a drain hole in the bottom of the channel so now when coolant goes in the channel it flows down the hole into the middle bore of the extrusion, down the tubing, and back into the machine.
    Attachment 289788
    warmachinellc.com
  1. wood door cnc router machine
    By gaosinicnc in forum For Sale Only
    Last Post: 01-22-2014, 07:25 AM
  2. Machine door snap pin
    By keith20mm in forum Want To Buy...Need help!
    Last Post: 11-02-2013, 06:38 PM
  3. Machine door safety lock
    By jkowal in forum Uncategorised MetalWorking Machines
    Last Post: 05-02-2012, 03:35 PM
  4. reason not to lean against the machine door
    By dertsap in forum MetalWork Discussion
    Last Post: 03-04-2011, 01:05 PM
  5. Replies: 0
    Last Post: 03-11-2010, 05:30 PM
