586,005 active members*
4,975 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > CITIZEN Machines > Questions regarding Citizen A20 and Citizen M20
Results 1 to 8 of 8
    Jun 2015
    Just took on a new position programming several Citizen machines. I've programmed everything they have in the past. The only two that are new to me is a A20 which is around a year old and a M20 which is a 1998 model.
    Looks like the A20 is a Fanuc control. With the M20 I'm not familiar with 3 channel programming.
    Could someone she'd some light on this and maybe a sample program.
    Feb 2011
    353
    Re: Questions regarding Citizen A20 and Citizen M20
    here is a sample program of an a20 type 7
    $1 is just turn and cut off
    $2is spot drill, drill and tap
    i use it as a template to start most jobs
    O00000000( )
    $1
    (PN )
    (A20-7)
    (DATE )
    G813(CANCELS SYNC)
    M9(CONTROLS BLOCK SKIP BACK TO MACHINE)
    G99
    M6
    /M52(OIL ON)
    G50Z[.510-.110]
    M3S1=2000
    (MATERIAL DIA+.100)
    G0X( )Z-.100
    !2L10
    G600
    T300(35 DEGREE .015 RADIUS)
    /B3
    S1=7000
    (MATERIAL DIA. +.05)
    G0X( )Z0T3
    (START TURN HERE)
    G1X-.05F.005
    (END TURN HERE)
    (MATERIAL DIA. +.100)
    G0X( )T0
    /B3
    M3S1=300
    T100(CUT OFF)
    (START CUT OFF HERE
    (X=DIA.+.05 Z=LENGTH+.505-.025)
    G0X( )Z( )T1
    !2L50
    M3S1=300
    M24S2=300
    G814
    M77
    G650
    M88
    !2L100
    !2L200
    M130
    G50S5000
    M3S1=4000
    G25
    G96S1=450
    (X= RIM DIA.)
    G1X( )F.005
    (X=RIM DIA. -.05 Z= LENGTH +.505)
    G2X( )Z( )R.025F.0015
    G1X-.050F.0035
    G813
    M131
    G26
    G97
    G600
    S1=750
    M89
    M8
    G4
    M8
    M108 U.02 C10.D.03B.06S750W2.300F150.A1.R1
    M9
    G4
    M9
    M3S1=750
    M7
    G4
    G0X-.050Z[.51-.110]
    M6
    G4
    M56
    M2
    M99
    $2
    G99
    G44
    M15
    !L10
    G600
    M88
    M23S2=6000
    T3100(SPOT DRILL)
    G0Z-.025T31
    G1Z.090F.0065
    G00Z-.025T0
    T3200(4.5MM DRILL)
    G0Z-.100T32
    G1Z.550F.009
    G0Z-.100T0
    M23S2=800
    /M61
    T3400(10-24 FORM TAP)
    G0X0Z-.100T34
    G32Z.3F.033
    G32Z-.100F.0416M24
    G4U.4
    G0Z-.125T0
    M89
    M25
    M33
    G0W2.2
    M16
    M10
    G4U.2
    M11
    M31
    T3000
    G50Z0
    !1L50
    G650
    !1L100
    M16
    /B4
    G0Z-.1
    (Z=GRIP LENGTH)
    G98G1Z( )F325.
    G4U.1
    M15
    /B4
    G4U.02
    G25
    !1L200
    G600
    M25
    M2
    M99
    (CHANGE MACHINING DATA)
    $0
    D
    #016=0000005000
    #020=0000001000
    #024=0000014000
    #028=0000001000
    #032=0000001000
    #036=0002000000
    #040=0000000020
    #044=-000000500
    #076=0000000000
    #048=0000002000
    #052=0000004000
    #060=0000601000
    #064=0000201000
    Oct 2007
    88
    I'd suggest you purchase WinCNC or similar. The older M-series machines may take the older G700 codes.
    Quote Originally Posted by chunkymonkey View Post
    Cincom M20 programming manual anyone?
    Thank you!
    304
    If you have already programmed the "L" series machines you won't have an issue with the M20.
    $1 is what your used to just tool numbers are different. (T11 - T18 instead of T1 - T9)
    $2 is the turret, T20 - T29, You have more tools and they can be used on either spindle.
    $3 is pickoff or support during cutting.
    THEN, you can go way beyond what your used to, like putting 3 tools in the cut at the same time, pinch turning, Pinch turning while supporting with the sub spindle.....
    Red face Re: Questions regarding Citizen A20 and Citizen M20
    Great info!, thanks a lot.
    What a piti cant find an original manual?
    "Why A ? I don't know." ver funny !
    304
    Can't upload Operator manual. Too large.
    Send me email at
    [email protected]
    Should be able to send it that way.
    Jan 2021
    Hello friends, I am looking for an operator manual for citizen cincom m20. can you help me.
  1. NEWBIE to Citizen - G32 thread whirling on Citizen L520???
    By jmonty in forum CNC Swiss Screw Machines
    Last Post: 09-07-2013, 06:50 PM
  2. i need help with a citizen f20
    By mackie67 in forum Want To Buy...Need help!
    Last Post: 04-16-2011, 12:00 AM
  3. Citizen L20,L25
    By humbertocnc2007 in forum CNC Swiss Screw Machines
    Last Post: 02-18-2010, 01:17 PM
