586,009 active members*
4,977 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Relationship between lead screw and pulley
Results 1 to 9 of 9
    Jul 2015
    5
    Hello guys I'm pretty new in this field and as I didn't find a plan for a cnc that suits my needs I try to design my own.
    My question would be what is the relationship between the lead of the screw if I have a lead screw on the z axis and the the pulley system from the y axis.
    Sent from my SM-T320 using Tapatalk
    Aug 2014
    42
    Re: Relationship between lead screw and pulley
    Maybe you need to describe it some more, as I'm not understanding what you are asking.
    If they're on separate axes then there isn't one.
    Sent from my XT1045 using Tapatalk
    Jul 2015
    5
    If for thé y axis I use a pulley and for the x axis I use a lead screw do I need to calibrate the motors separately?
    15362
    Quote Originally Posted by Eduard77 View Post
    Yes if each axes has a different ratio or the screw pitch is different, then you setup each axes, you should always calibrate each axes anyway, as there can be slight differences in the pitch of the screws/belts/rack & pinion being used
    Mactec54
    Jul 2015
    5
    Do you know a tutorial how to do this?
    15362
    It depends on what control software you are using, some have an axes calibration built into the software that you can use
    Mactec54
    Jul 2015
    5
    I will use mach3
    I will search for a tutorial according to this software
    Thank you
    15362
    I will use mach3
    Mach 3 has this feature, open Settings, then look above the Reset Button, you will see axes calibration, it is easy to use, there are many Youtube videos on how to do this
    Mactec54
    Jul 2015
    5
    Thank you
  1. Lead Screw pitch and Bearings,coupling for lead screw
    By Power_user_EX in forum Linear and Rotary Motion
    Last Post: 06-12-2012, 12:37 PM
  2. How do you mount a lead screw/lead nut?
    By jbluetooth in forum DIY CNC Router Table Machines
    Last Post: 12-01-2008, 11:10 PM
  3. Steppers and Ball Screw Relationship
    By Mr.Chips in forum CNC Machine Related Electronics
    Last Post: 01-01-2008, 08:13 AM
  4. Belt vrs. Ball Screw vrs. Lead Screw
    By stevesplanes in forum Linear and Rotary Motion
    Last Post: 01-09-2006, 06:23 PM
  5. New technology.... old debate.....ball screw vs lead screw
    By trubleshtr in forum Linear and Rotary Motion
    Last Post: 08-16-2005, 02:42 AM
