Hi All, just checking if anyone has had experience with importing Rhino sketches into Solidworks. I have a Romer 6 axis digitising arm that I run directly in Rhino and even though I do my surface modelling in Rhino, I prefer to do my engineering stuff (solid modelling) in SolidWorks. My normal work flow is as follows: I do my finished base sketches in Rhino then do a save as to another file and make this a very simple file with one layer only as a sketch (not a surface nor a solid) and I generally stay with lines, circles and arcs and stay away from splines where possible so there is less translation to be done. I believe that the earlier in the process the import/export is done the better. I do the import into SW using IGES format.
So that is my process and it works but has several draw backs although not major ones. The imported stuff ends up as a long list of "imported curves" so then I have to do a sketch and use convert entities on every single "imported curve" to re-do them. Also all the circles end up as 2 half circles so I have to redraw them all. I can live with these but is there a better way? Is there someone who does this kind of thing regularly and has a more efficient way? Another format instead of IGES maybe? Supposedly SW will accept 3dm files (Rhino) but when I tried to import the sketch it said something about a lack of surface/solid data. Next I tried doing a straight extrude in Rhino to make it into a solid just for the sake of the import into SW but I got the same message.
Any help would be greatly appreciated.
I've posted this in the SolidWorks section as well as I can't see a way to post in both with one post so (moderators) please modify if required. Thanks
