My machine is 4'x6'. I am going to use ball screws to control the linear motion. (If anyone thinks I should use rack and pinion please give me your thoughts)
The ball screws I am looking at are McMaster part number 5966K13 for the shaft and 5966K17 for the nut.
These are 1" dia. shafts, teeth per inch are not listed but a screw lead of 1/4" is. Anyone know how many TPI?
Questions--
1. Are these suitable for my machine? (I'll be making wood signs and etching aluminum and small (12" x 6") moldmaking.
2. These are rated at 1612 lbs. load capacity, is that enough?
3. Can I get away with only 1 nut on each axis to mount to the gantry and z-axis?
4. Can I get away with only one shaft on the y-axis (the 6 footer)?
Thanks Guys.
