585,748 active members*
3,498 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Cincinnati Milacron Sabre 750 ERT parameter list
Results 1 to 6 of 6
    Aug 2015
    We have lost of the parameters of a Cincinnati Sabre 750. We have input manually some of them but the machine it is still not working.
    Could anyone else provide us with a parameters list of a similar machine?. It would be greatful as a start point.
    Thanks!!
    Dec 2006
    584
    Re: Cincinnati Milacron Sabre 750 ERT parameter list
    What control do you have on this machine????
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Aug 2015
    It has a Fanuc 0M. The complete caracteristics of the machine are:
    Cincinnati Milacron. Sabre vertical
    Machine Type: Sabre CNC Vertical machining centre.
    Model: 750
    Mark: ERT
    M/C Ref nº: 711
    Machine serial: 7029-F00-RE-0711
    Customer order: 16299
    Model Work order: 702079
    Year: 1993
    Control type: Fanuc 0 M C
    Control serial nº Fanuc: 2061696
    Aug 2015
    We have managed to find the parameters list. However we do not have the 900s (from 900 to 940). We have tried some of them but, still, the machine it is not working.
    We do not have alarms but we can not move any axis or homing the machine. It seems that the operator panel it is not working, there is not any light on when you press them. Any idea?.
    Mar 2010
    8
    I have ARROW 750 parametrs [email protected]
    Nov 2015
    Hello sir, I am Mr. ARNAUD ZOGNING from Cameroon, I come to you to ask for help because I had a problem on my sword MCT 750 fanuc cincinnati and I think you had to go through the same situation. The problem is this: Tool change in MDI and even automatically in a program is not responding. Before you write, I did a search over internet it has made me understand that the macro O9000 that manages the tool change must be either missing or changed. How to bypass this problem, because I'm really stuck at this level more than three weeks.
    Here I receive alarms according to the work mode,
    1 In MDI
    T01
    M06
    Start cycle
    Alarm 1028 using the wrong program number 6
    2 In AUTO mode
    O0239
    T01 M06;
    Alarm 078 P / S ALARM
    AND ALSO
    Alarm Error Code 1054 Pogba T WITHOUT M06
    I really count on your support to break the deadlock.
    Thank you very much, Mr. and spend a pleasant evening.
