Re: DIY Guide rails?
I think you are on the right track. I looked at using heavy duty dual door wheels which have a stainless steel wheel with a 5mm radius groove so it will run on the edge of 5mm angle iron but as I got into it, I figure with what you have to do you might as well do it right and go with the Hwin rails. There is some good pics on Willy's build thread from Muzza using the round rod instead of Hwin rails. I'm still struggling to sort out all of the electronics on my build thread but have made a bit of progress on the wiring on my build thread.
So let me know what size rail you choose....
Rod Webster
www.vehiclemods.net.au
