Well on my build someone mentioned that I should step away from slave axis of my x due to safety.
I'm running 600oz servos on 5mm lead screws and wondering if there is a safe way to slave this axis without using belts etc. I guess the big reason would be if motor 1 stops turning, and motor 2 continues turning with all it force, things are going to break. My question is, with a closed loop system of servos, is there a way for the machine to estop if this occurs and the machine starts racking? Is this a software deal or a harware deal? I'll be running smooth stepper ethernet with a c23 board.
Sent from my SM-N910V using Tapatalk
