584,850 active members*
4,330 visitors online*
Results 1 to 6 of 6
    Mar 2011
    24
    Unhappy gecko 320x drive
    Just got a new dive to replace my g320 .....hook up just the same way as the original but
    it is faulting all drives after I reset them.....I am a woodworker and not an electrical engineer.
    When my z axis did not respond I check several things. I then switch that drive with one
    that was working and the z worked and the other did not..Therefore I ordered a new one
    and as soon as I hooked it up in the same way as the other it is in fault mode....As soon
    as I reset all drives they immediately fault......
    need some troubleshooting suggestions.......HELP!!!!!!!!!!!!
    Nov 2015
    10
    Re: gecko 320x drive
    Did you ever figure out the issue? I'm having the same kind of problem.
    Sent from my iPad using Tapatalk
    Jul 2005
    2415
    Are all of thr drive G320X's or just G320? The fault/reset pin may be different. Some designs tie all of them together. If its wired with wire you can try pulling the wire to the fault/reset pinon the new drive (it may not come out of fault) and see if the other drives power up. I would contact Gecko , they have a good support group.
    Mar 2011
    24
    Quote Originally Posted by davidvan326 View Post
    It turned out both the drive and the encoder was bad.
    Got a digital encoder and can't recall the name but can
    find out and send it to you. All is well now....good luck
    Nov 2015
    10
    My drivers are 320x. Mine won't reset even using the reset jumper wire. I called gecko, all their technical staff out of the office till end of the week. Been searching the forums for similar problems. Thanks for the reply!
    Nov 2015
    10
    How did you determine that the drive was bad?
  1. Gecko 320x won't reset from fault
    By thunderdork in forum Gecko Drives
    Last Post: 05-19-2015, 12:50 PM
  2. Will A Gecko 320X drive these?
    By Jackal66 in forum Gecko Drives
    Last Post: 11-08-2011, 02:01 AM
  3. Gecko Drive 320X and PIC (STEP)
    By netomx in forum Gecko Drives
    Last Post: 10-03-2011, 05:43 PM
  4. Gecko 320x noise is this normal?
    Last Post: 09-12-2011, 03:45 PM
  5. Why use breakout board with Gecko 320X?
    By pp7 in forum Benchtop Machines
    Last Post: 04-18-2011, 08:10 AM
