585,930 active members*
3,219 visitors online*
    Aug 2015
    4
    laser mirror align problem, OR NOT
    hi guys, first of all thank you all for being here, i have bought a mactron 2300x1500 and recently i changed the tube, replaced it, because it started to sparkle. i have made the alignments so wherever the laser moving head is the beam enters the hole. there is just one problem, when the head is near to the second mirror it cuts and engraves perfectly, but when i send it on the far end of the machine, the power starts to drop. its driving me crazy. i have worked 3 days in a row trying to figure out. So i would really really appreciate it if i could find some support here thanks in advance
    Nov 2008
    382
    Re: laser mirror align problem, OR NOT
    hi there
    2300mm its a far way for the beam you need something like a expander lens lock at lightobject marco sells some.
    greetings
    waltfl
    Aug 2015
    4
    before it was working fine. then it started giving this. its 130w tube
    Nov 2008
    644
    The larger the machine to more precise the alignment. I use wood disks the size of the mirrors and work carefully from the tube to the lens. Use low power and always hit the center of the wood at all orientations. Never tape mirrors. Replace the wood with the mirror after you prove that the beam is in the center To be safe shut your eyes when you test fire. Should take a couple hours if you haven't done this before
    Aug 2015
    4
    yes, the larger the machine the more precise the calibration, problem is that i cant move the second mirror, it does not have an axis so i can align it, its static
  1. CINC MILACRON ACRAMATIC-850 ALIGN PROBLEM
    By keyancnc in forum Cincinnati CNC
    Last Post: 08-15-2016, 06:10 AM
  2. Align problem
    By mike sr1 in forum Rhino 3D
    Last Post: 10-17-2013, 08:29 PM
  3. Align beam in laser engraver
    By siciait in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-01-2012, 03:14 AM
  4. Laser Engraving on a Mirror
    By rcpilot82 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-14-2011, 12:39 PM
  5. Align Honing or Align Boring ?
    By jonbanquer in forum MetalWork Discussion
    Last Post: 11-09-2008, 04:33 PM
