585,589 active members*
2,918 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > MILL TURN RADIAL MILLING
    Sep 2010
    86
    Hi Mates,
    I want to mill the radial holes on a Cnc mill turn.
    The axial holes have been milled without any problem.
    However, the issues arises with the RADIALS HOLES .After setting the tool as radial and selecting the holes, Edgecam is throwing an alarm THE ENTITY DOESNT LIE IN THE PLANE OF CPL.
    Thanks in advance for your input.
    Re: MILL TURN RADIAL MILLING
    Make a radial feature with axial cpl on then it will recognize the radial feature then.
  1. Mill Turn / Turn Mill / Multi Task C Y B Programming
    By aldepoalo in forum BobCad-Cam
    Last Post: 04-22-2015, 09:31 PM
  2. Mill Turn / Turn Mill / Multi Task C Y B Programming
    Last Post: 04-22-2015, 09:24 PM
  3. Replies: 0
    Last Post: 10-17-2013, 02:29 PM
  4. RETROFIT OF RADIAL DRILL MACHINE INTO CNC MILL
    By Khalid in forum Uncategorised MetalWorking Machines
    Last Post: 06-18-2012, 02:22 PM
  5. Compensation in Mill-Turn Profile contour milling
    By maparkopo in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 03-26-2012, 03:11 PM
