585,973 active members*
4,213 visitors online*
    Jan 2007
    161
    RPM / G76 canned cycle
    Hello,
    I default to 1000 RPM when single point threading on my CNC Fanuc OT 1999 control. Currently I am cutting a 3/8-16 thread in stainless and it is running good. I have cut air at 2000 RPM and seeing how fast the machine is moving and wondered if it is too hard on the machine and if there would be thread pitch error.
    Any experiences with faster RPM's? I know surface footage comes into play on larger thread diameters but what about smaller diameters.
    _____________
    teamjnz
    Aug 2008
    Re: RPM / G76 canned cycle
    The faster the RPM the more pitch error you will see during lead in and lead out. The middle portion of the thread my be fine. I have found that diameter (SF) and pitch control what RPM I run. The finer the pitch the higher the RPM.
    Oct 2014
    You can thread that pitch at 1500 with out any problems .I do all day long on fanuc ot on a miyano remember the control only cares about is IPM..
    15362
    teamjnz
    It will depend on how good your tooling is, I run that size in O1 material at 2302 RPM F22, and this is conservative,
    Mactec54
  1. TL-2 IPS Canned Cycle
    By gtkemp in forum Haas Lathes
    Last Post: 06-06-2011, 01:58 PM
  2. Canned Cycle Help
    By vanbry in forum Okuma
    Last Post: 12-15-2009, 12:48 AM
  3. Canned cycle
    By tsaladyga in forum Post Processors for MC
    Last Post: 08-30-2009, 12:31 AM
  4. Canned OD cycle?
    By VWbmx in forum Haas Mills
    Last Post: 06-05-2009, 06:17 PM
  5. G76 Canned cycle
    By Stebedeff in forum Fanuc
    Last Post: 02-07-2008, 06:42 PM
