585,975 active members*
4,487 visitors online*
    Nov 2009
    159
    Post New Proton Z axis ( plus - Retrofit info)
    Specs
    1606 true ball screw (lubed, double seal, double anchored)
    25MM rails (Lubed, twin triple seal with scraper on each)
    Servo soft limits available
    Magnetic breakaway (MAG-LOK v.2.)
    Powder coated sheet metal enclosure with quick access
    5/8" thick
    Torch bodies up to 2.00"
    Integrated with 800 RPM motor (When installed on Proton machine)
    Up to 4.5hp router capable
    Angular compass up to 65 degrees (from 0 to 60 degree angle cuts (infinite ratio)) available
    Twin pocket auxiliary tool pockets with 3 tapped holes for rigid tool bracket mounting
    Retrofit Proton Z axis includes all the the above except
    - - - Updated - - -
    This section intentionally left blank for picture reserve
    Now featuring Plasmaland online
    Nov 2009
    159
    Re: New Proton Z axis ( plus - Retrofit info)
Name:	proton Z axis 5 small.jpg
  1. Looking for spare parts catalogue for Knuth Proton 530/540
    By Snailass in forum Machinery Manuals / Brochures
    Last Post: 08-16-2012, 09:28 AM
  2. Retrofit 6 axis robotic arm?
    By diyengineer in forum Want To Buy...Need help!
    Last Post: 12-16-2011, 10:04 PM
  3. VMC retrofit Z axis assist?
    By wyobmf in forum Uncategorised MetalWorking Machines
    Last Post: 12-30-2008, 05:01 PM
  4. 3 axis mill retrofit
    By beezerlm in forum Mach Mill
    Last Post: 03-21-2008, 03:36 AM
  5. BP S1 Z axis retrofit
    By CNC OT in forum Bridgeport / Hardinge Mills
    Last Post: 09-05-2007, 09:42 PM
