I need a replacement 2 pin connector for the lamp on my Mitsubishi FX10 wire EDM machine. It's a stainless steel screw type connector for the lamp. I had a source but have lost it and the part number.Any help would be great.
Try Newark Electronics. Newark element14 | Electronic Components Distributor
If it's a wire to wire mating connection you can always cut off the old connection and put on whatever you want - make sure it can handle the amps/volts/environment if you do that.
