Model LC1530M, LC1325M, LC1313M, LC1390S- Metal non-metal ,LC1325H,LC1325D metal non-metal
Working size ,1500*3000mm,1300mm*2500mm, 1300*1300mm,1300*900mm
Laser power Reci W6(130w-150W) , Yongli 260w as option
Cutting speed 0 – 60mm/s
Reposition accuracy ±0.05mm
Working voltage AC110- 220V±10%,50-60Hz
Consuming power less than 1,000W
Working temperature 0 - 45°C
Working humidity 8 - 95%
Minimum letter size English :1 x 1mm Chinese:2 x 2mm
Supported file format BMP, HPGL, PLT, DST, DXP, and AI
Driving system Panasonic Servo motors
Laser tube cooling type Water-cooling chiller LW16 or cooling machine and protection system
Other auxiliary equipment Exhaust-fans and air-exhaust pipe
Laser control software DSP control system
Compatible software CorelDraw AutoCAD Photoshop
Laser tube type: Sealed CO2 glass laser tube
Standard configurition:
1, USB port
2, Beijing RECI laser tube(the best quality one chosen from hundreds of tubes)
3,Doluyo Chiller LW-16&air pump
4,Japan Panasonic Sanyo servo motor(high precison)
5,Taiwan lead ball screw& Hinwin linear guide
6,Y axis DUAL ball screw
7, Auto-adjuster (Charge Sensing)
8, German copy laser head
9 ,Z axis automatic tracking
10, American Imported 26 mirrors &focus(water coolling)
Available materials:
Stainless steel,carbon steel.other thicker nonmetal materials like acrylic,MDF etc
Available gas:
O2(Oxygen)
LC1325M 260w or 150w ,LC1325H, LC1325D, LC1390S, metal non-metal laser cutitng machine .
Quiven from gweike laser www.wklaser.com
skype: wkquiven
[email protected] Attachment 290230
