584,866 active members*
5,081 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > Engraving Settings for a Victory Original Series Brass Plaque
    Aug 2015
    Post Engraving Settings for a Victory Original Series Brass Plaque
    I have a 60 watt laser and am wondering if anyone know settings for .019" thick High polished brass with clear lacquer coated with ultra thin color,
    It is brass-plated steel.
    Does anyone have recommended setting for power, speed, and ppi?
    Thanks a bunch!
    Feb 2010
    155
    Re: Engraving Settings for a Victory Original Series Brass Plaque
    eaglestone:
    I assume you are using a 60W CO2 laser? A CO2 laser can't etch bare brass (or brass-plated steel) unless you use a coating like Cermark/Thermark.
    Does "clear lacquer coated with ultra thin color" mean it is painted a color and then clear coated over the paint? If so, you can etch away the clear coat and the paint with a CO2 laser. This should require very little power. If you mean it is brass-plated steel with just a clear lacquer coat, then you can etch away the lacquer, but I don't think you will be able to see much contrast between the etched and non-etched surfaces.
    -robertk925
    wklaserliu Guest
    Quote Originally Posted by robertk925 View Post
    eaglestone:
    -robertk925
    HI Robert,
    Yes, you are right,
    co2 laser engraving mahcine not ok to negrave on bare metal ,if metal with a layer of paint or oxygen layer then ok to engrave.
    if engrave on bare metal then need fiber makring machine
    Quiven form Gweike laser www.wklaser.com
    skype: wkquiven
    [email protected]
    Aug 2015
    Here is the manufacturer's description.
    "SSB Series is our premium sheet stock. High polished brass with clear lacquer is coated with
    Victory's ultra thin color, providing ease in standard engraving and bright glossy laser
    engraving. SSS Series maintains the same standard but on economical brass plated steel. The
    SSS Series is available in a larger variety of color."
    Feb 2010
    155
    eaglestone:
    If the material is designed for laser engraving (which it sounds like it is), then the vendor is probably your best source for recommended laser settings. I would guess that it doesn't take much laser energy to etch, so maybe start with 20% power and 300mm/s and work up from there if necessary.
    I like to use the following chart as a guideline:
    http://www.rabbitlaserusa.com/Manual...dsFeeds_RL.pdf
    -robertk925
  1. Engraving Brass.
    By REVOFactory in forum MetalWork Discussion
    Last Post: 01-09-2011, 05:14 PM
  2. Original Bridgeport CNC Series 1 acceleration?
    By lfleiva in forum Bridgeport / Hardinge Mills
    Last Post: 10-06-2010, 11:27 PM
  3. Engraving Brass
    By TheMadEtcher in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-25-2010, 06:58 PM
  4. 2nd cedar outdoor plaque of a series
    By woodman08 in forum Gorilla CNC Machines
    Last Post: 06-22-2009, 08:04 PM
  5. Engraving Brass
    By Tony Mac in forum Vectric
    Last Post: 03-28-2006, 05:16 PM
