Hi All,
I am trying to connect with Fanuc ladder iii using the ethernet port on the front of the Oi-MD control. Typically i just use a memory card to transfer PMC changes, but I want to connect with my PC. There is an ethernet cable connected to the control from the access panel port so I would figure this is usable.
It is not working any way I try..
I will describe the setup I am using and wonder if anybody has done this?
Parameter 0020- 9 (embedded ethernet)
Parameter 14880- bit 0=0 (embedded ethernet port used)
I set my laptop to IP address 192.168.60.20
I set my laptop subnet address 255.255.255.0
I select embedded ethernet port on CNC (common) softkey IP of CNC already set to 192.186.60.10 subnet 255.255.255.0. No router IP.
I am connecting directly with a crossover ethernet cable.
FOCAS2
The port number TCP is 8193
The port number UDP 0
My Fanuc ladder IP communication is set up to 192.168.60.10 to see the CNC.
When I try to connect I am in the POS screen.
When I try to connect It says connecting for like 20 sec then disconnect.
The task status screen under PMC shows W then D then when it disconnects it goes back to X.
Can anybody see what I am missing??
Thank You!!
