585,927 active members*
3,876 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > can this be done with dolphin?
Results 1 to 6 of 6
    Nov 2006
    69
    this block is mounted at 45 deg.No real help[ from dolphin.
    Jul 2010
    180
    Re: can this be done with dolphin?
    Of course. Mount it on 45 degrees and treat it as a flat surface. If depth is an issue, flip it.
    If all that's an issue, other 2D CAM support ramping and/or 3D cutting.
    Oct 2008
    78
    For what it's worth, Dolphin can cut this feature on a part mounted flat using the merge function. The part would need to be flipped to perform the same operation on the other side.
    As per this video from years ago
    https://www.youtube.com/watch?v=mn8s6wBo--U
    Jul 2010
    180
    Quote Originally Posted by dblox View Post
    This won't work. The reason it works in the example given is because the contours are distinct or seperate. In the case of the part given in this question, 3 of the 4 edges or are directly above each other (looking from the top view). As Dolphin CAD is a 2d system it doesn't allow you to trace contours twice....
    https://www.youtube.com/watch?v=OV-lCgsX9Vk
    Oct 2008
    78
    Not really sure what you are talking about there FastFarmer, the two contours that need to be merged are both open and do not overlap. Pretty much like two open brackets next to each other " [ [ " the left one being the top and the right one being the bottom.
    That's how I made the part in the video.
    Jul 2010
    180
    What you are saying is for the chamfer you have two parallel lines, say one at z0 and one at z-20, then for the remaining, I pocket the box.
    I was thinking as one operation. But, yes, I accept that will work for the part in question! Cheers
  1. Dolphin Demo / Dolphin Sales / Dolphin Support
    By Dolphin USA in forum Dolphin CAD/CAM
    Last Post: 10-28-2012, 05:28 PM
  2. looking in to Dolphin cad/cam help
    By blighty in forum Dolphin CAD/CAM
    Last Post: 06-22-2011, 11:48 PM
  3. I Need Help getting to know Dolphin CAD/CAM
    By Minna in forum Dolphin CAD/CAM
    Last Post: 12-10-2008, 03:29 AM
  4. Thank you Dolphin
    By ImanCarrot in forum Dolphin CAD/CAM
    Last Post: 03-17-2008, 10:35 AM
