585,973 active members*
4,114 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport Explorer I Hard drive Software HELP Needed!
    Aug 2015
    Hello. New to forum. Have an explorer 1 that the hard drive went out on and got a replacement and think I managed to save most the files to move over but lost the registries. Does anyone have or know where I can get a list of the files that are necessary to run. Or if I start from scratch, where I can find the proper software on line. I did see an older posting that indicated that v2xt boot disks were on a yhaoo group (in 2004) but am not even sure that is the software I need. I do know my machine uses the BMDC and had dos 6.2. Any help or direction would be greatly appreciated. Also love to just connect with others who have an Explorer 1. I've had the machine for several years with no problems til now, but am sure interaction with others would be most helpful.
    Chris
    Nov 2004
    3028
    Re: Bridgeport Explorer I Hard drive Software HELP Needed!
    You can get the software from EMI. If you have purchased a hard drive, you will have to FDISK it to 504MB, format, load DOS, and then the machine software. You may want to consider a Disk on a Module.
  1. Bridgeport Torq-cut 22 forgets its hard drive
    By Alley-Way in forum Bridgeport / Hardinge Mills
    Last Post: 10-16-2016, 04:37 PM
  2. Will share computer software from Bridgeport Explorer X26
    By TommySteele in forum Bridgeport / Hardinge Mills
    Last Post: 11-24-2013, 06:11 PM
  3. Bridgeport Torq-Cut 22 lost hard drive settings
    By oldcastletool in forum Bridgeport / Hardinge Mills
    Last Post: 10-26-2011, 10:23 PM
  4. software vs hard drive
    By Claude Boudreau in forum BobCad-Cam
    Last Post: 01-28-2011, 08:44 PM
  5. Bridgeport Explorer DX 32 Programming Software
    By minton in forum Bridgeport / Hardinge Mills
    Last Post: 09-27-2010, 02:01 PM
