Hi, I am getting a new to me ML-20 Monday. My concern is preparing a proper ground for the machine. This is the existing set-up I have:
My shop is next door to the main shop where the 3 phase power comes in.
From that point the power comes under ground and up into the service box in my shop. There is an existing run of 3 wires (no ground wire) to the spot I want to set the machine.
The landlord says the previous machine that ran there was a large surface grinder that used the conduit as a ground. (I've read enough on here to know thats not a good idea.)
The building has a ground rod in the front left of the building with a wire that runs across the top of the building to another ground rod in the right rear of the building and along that wire span
on top of the building are 3 equally spaced small rods going up from the wire. I assume for lightning protection. The landlord says it was that way when he bought the place.
Any suggestions would be greatly appreciated.
Thanks,
Scott
