585,981 active members*
4,151 visitors online*
Thread: hummnnnnn
Results 1 to 3 of 3
    Apr 2012
    141
    hummnnnnn
    so i am getting a little more comfortable with my machine and have been upping the gains
    iirc its at 100-50-50 , but now there is a humm when the machine is stationary , the moment it moves it goes quiet ... anything to be concerned about ?
    this is on the dyn2 kit
    so far i can get real nice cuts at 6m/min in MDF with a 10mm bit at 10mm doc , corners are sharp and machine seams happy
    at the lower range doing engraving or v carve, the machine seems a little tight , or almost bouncy , making me think i should lower the gain ?
    tuning recommendation
    Jan 2007
    599
    Re: hummnnnnn
    lower the gain a touch
    15362
    Re: hummnnnnn
    Quote Originally Posted by Bl@ckrat View Post
    Your gain will depend on how much load the motor is pushing/stopping, you most likely don't need much over 65 38 14, a 100 sounds extreme, see if you can still get sharp corners at 65
    Mactec54
