Originally Posted by
Ydna
This may be a dumb question, does the alarm state "overtravel" or does it say "range error"? The reason I ask is because range errors are usually associated with unknown codes (typos etc), like if you instructed the machine to use T123456.
Anyway, have you tried inputting any code into MDI to test the offset? something like this...
G0 G90 G43 H1 G154 P17 Z10.0
Does your probed work offset Z-value make mental sense? It should be the distance to bring the spindle nose from machine Z-zero over to the programmed zero on your workpeice. If the value is much too large then there might be a calibration problem..
